Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Problem With Liliput EBY701
  1. #11
    Low Bitrate angel120's Avatar
    Apr 2008
    Queens, NY
    Quote Originally Posted by Xoxol View Post
    What about any other usb devices? Like kb, mouse, flash drive? I understand you also tried this screen onto two other laptops but vista in not counted)
    GPS (BU-353), PS/2 mouse, USB mouse, PS/2 keyboard, and my USB external hard drive all work fine. I also tried an SD-USB adapter, and that worked fine. I've switched the USB ports around as well (putting the touch on 'port 1', gps on '2', and vice versa).
    2003 Mazda 6i Sedan - White
    CarPC in the making!
  2. #12
    Nov 2007
    so... I believe there are the options: screen itself, damaged usb cable or somehow corrupted drivers. Dont really know what else could be...
  3. #13
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    FWIW this happened with my Shark screen also. I had plugged in the USB controller plug the wrong way. Not the USB plug itself , the little molex connector that connected the USB touchscreen interface board to the main controller board.
    It could be plugged in 2 different ways and I did it wrong. Kept saying "USB device not recognized" . Unplugged it and moved it in the right position and it was fine.
  4. #14
    Nov 2007
    for Lil there is no way to plug it wrong.
  5. #15
    Apr 2008
    Queens, NY
    I hope the USB extension cable isn't damaged, I just bought it! lol
    I'm not sure about the Lili cables though.. I do have a little bit of wavy lines on my screen (happens only when the engine is on and I also have alternator whine in my speakers, but that's a different problem, right?). Other than the wavy lines, the video is fine, which makes me think that the Lili cables are fine.. I'm not sure how other Lili monitors have their cables, but mine has a small unique plug on the back of the monitor that goes into a thick cable which then branches off into RCA audio & video, VGA, USB, and power.
    The drivers, well, unfortunately, I don't have a CD drive on my CarPC (I don't have a working adapter for IDE-slim). What I've been doing was copying the CD onto the carPC's hard drive, and running it from there.
    On the Vista laptops, however, I've been using the CD.
  6. #16
    Nov 2007
    just to check - did you make sure the connector from the back of the screen is plugged in tight?
  7. #17
    Apr 2008
    Queens, NY
    As far as I know, it's fine. One time I had it loose, and the screen was just bright green or red, so I moved it and it was fine. The plug seems fine right now. When I was troubleshooting, I kept moving it around, and there was no difference. Next week I'm gonna take out the lili and do a bench-test, maybe I'll have some luck..
  8. #18
    Apr 2008
    CO
    Make sure to let us know what you found out.
    Working on my Comp TIA training.
  9. #19
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Hinges?
    How has the screen been modified? Please try to be a specific as possible and describe all the modifications no matter how small.
    If you (or someone else) has attached a hinge with screws, it's possible one of the scews has shorted or dislodged something inside the monitor.......
    Leonardo Da Vinci
  10. #20
    Apr 2008
    Queens, NY
    Quote Originally Posted by greatwhite View Post
    Hinges?
    It's mounted with hinges that are attached to the lid of the mapbox. I know he used an adhesive to attach to the lid, and I'm 95% sure he used adhesive to attach the hinge to the housing as well. I'll post more pics tomorrow, hopefully.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  3. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. Another problem with 7" Liliput
    By terence729 in forum LCD/Display
    Last Post: 07-11-2004, 09:14 PM
