Are you sure that it is the screen? Do you have an inverter in the car? Because inverters are known to cause a lot of interference. If you want to reduce the amount of interference that the screen makes, though, first run it off of a separate power supply so that the screen will not let interference onto the main power lines. In addition, you could buy better-shielded signal lines for the screen. If the screen continues to create this much interference, I guess you could buy some brass mesh and try to shield it like a faraday cage, but that's way over the top. If that is the case, you should probably consider your warranty options.
LinkBack URL
About LinkBacks
