personally I would go with gooddeals18 dot com.
That have good prices and ship quick...
Hi,
I have done a lot of searching about what system to put into the car and am set on a carpc. I have searched the forum for screens the sizes I am looking for but cannot find any information. I need help selecting good screens for my build. I am looking for a 9" widescreen touch screen to be molded into the dash and a 15" wide screen for the trunk.
Both screens are going to be molded in so I think it is easier to do with non framed screens.
Can anyone recommend any screens or a good website where I can find them. I need the front one to work well in sunlight etc, the trunk screen is not so much of an issue.
Thank you for your help!
I have just found these two screens, they are not touchscreen but a (" touchscreen is seeming to be very hard to get hold of! Do you need extra components to run them? Also why does the non VGA one have a better resolution and which would be a better choice? Is there a way of making them touch screen?
9" screens:
http://www.mobilevideozone.com/produ...6-2569AF9099FC
http://www.mobilevideozone.com/produ...C-C29D9ED7543E
15"
http://www.mobilevideozone.com/produ...1-289206F33F6D
Thank you
Just found this 9.2" touchscreen, but the resolution seems very low:
http://www.mobilevideozone.com/produ...D-E82B38D89648
Is it possible to take these screens out of the casing to mold them into the dash?
Native resolution of 800x480 is very typical for 7" - 9" displays.
Some will list higher but that is not dot-to-dot on screen.
Oh ok .. it seemed a little on the low side.
In that case is there anything else I should look out for? I mean are the screens linked above good enough for what I am looking for? (i.e. to have in the dash of the car with the sunlight hitting it)
And my other question: if a screen comes in a casing (e.g. a roof mount monitor) are there any issues in taking it out of the casing and mounting it in the dash?
Found a nice 9.4" widescreen roof mount screen and a 9.4" touchscreen that I can use with it.
