Nah, you can snag one off ebay for around 40 bucks, mithc's cable for 25 if I remmeber and you're good to go.
You just have to be patient and watch ebay for a while.
Cheers
looks good. Another $100 + ..it never endsIm not sure what FE i will be going with or if Im even going to go with a FE. Wonder how that works in Win XP without a front end
Cheers
Leonardo Da Vinci
Greatwhite ... Do you know if you have to use a supported FE or will it work with Xp by itself? Im geussing it wont becouse it would need some sort of installable software.
Yea, what Greatwhite said.... only about $70.00 to $80.00. Mitch provides you with a program to use it in Windows without a frontend. Centrafuse has HD support coming in update 1.48, and Mitch also has a RR plug-in.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
RR supports it, appaarently Cf does by 'jack's post.
It wil also work stand alone in Xp with Mitch's software (PCR) available on his site (www.rush2112.net).
Cheers
Leonardo Da Vinci
Cool...I may have to check it out later. I got my amp installed and new speakers on the way. Now buy bezel and a couple small things and im up and running. Be a month or so![]()
