after many problems and fixed those problems this got me stuck.... i have a lilliput 629gl used to work fine but after putting in the screen in the dash. turn it on and it a lot of lines and a white screen... and da weirdest thing is dat when it turns on i see some spelling. i think it says "oriet"? not exactly sure but im very disappointed.. i dont kno what else to do anymore.... thinking about giving up on my carpc and jus buy poineer d3 or something.... i will try to get a picture of it asap
That looks like the Jurassic Park thing. It probably means one or both the flat cables are not seated properly and need to be adjusted.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
i hope your right im going keep messing with it
i think i found the problem my ribbon is pretty messed up from taking it out and in.. where can i found a replacement?
hey your right!! da ribbon to the board was loose! and i cut part of the ribbon tooo.. thanks a lot!! hahah
