Results 1 to 2 of 2
Thread: Looking for Worcol Touch
    Sep 2007
    West Springfield, MA
    I had Worcol Touch on my first Carpc build. It came on the small disc that was with my Lilliput, but do to the fact that I own a cat that seems to be teething very late, I do not have the disc anymore. I managed to get Touchkit for my new Carpc, but I miss the small box that I had with Worcol that would cycle between left and right click. Also, Worcol had a 25 point calibration where Touch kit only has 4 and 9. If anyone could help me out, even if I buy a copy of a disc that someone makes, I would appreciate it.
    Mar 2006
    Colorado, but Canadian!
    Touchit has that little thing in the bottom corner. Click the system tray icon and there is an option to make it appear. Also you can setup auto-right click so the longer you hold it eventually turns into a right click. It is a very simple solution.
    And calibration is 4 or 9 point, but then linearization can be 25 point. It is an option in the menu area.
    1.9in x 2.9in -- 47mm x 73mm
  1. how to fix your disfunctional touch panel
    By numbers in forum LCD/Display
    Last Post: 08-08-2011, 10:54 PM
  2. Touch Screens ultra fragile?
    By kn_tl in forum LCD/Display
    Last Post: 03-15-2008, 10:41 PM
  3. Replies: 3
    Last Post: 08-18-2005, 01:03 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. UPDATE ON: TM-701L and Touch Screen Kit
    By digitalww in forum LCD/Display
    Last Post: 07-12-2003, 12:39 AM
