Results 1 to 6 of 6
Thread: 6.5" vs. 8.4"
    Jan 2006
    6.5" vs. 8.4"
    I was hoping to gather some opinions on two LCD configurations I have been looking at:
    Screen One:
    6.5" XGA-1024x768
    500:1 Contrast
    25ms Response
    650cd/m^2 Brightness
    Antireflective Coating
    Viewing angles Up: 80 , down: 60, right: 80 , left:80.
    Capacitive USB Touch Screen
    LED BACKLIGHT!
    Screen Two:
    8.4" SVGA-800x600
    600:1 Contrast
    25ms Response
    Dual-CCFL BACKLIGHT
    The price difference between the two is about $20USD (cost of the CCFL inverter), so it really doesnt weigh in.
    Both would be put into a custom console/dashboard, probably SLS.
    I like the idea of a LED Backlight, but 6.5" is very small, however it is an XGA resolution. However a 8.4" is substantially bigger but its less resolution. The extra 50nits of brightness could help, however CCFL do have a lifetime 1/2 of the LED backlight.
    For me at the moment, they are tied in the race..compact high resolution or alternatively, bigger screen, lower resolution.
    I am swinging towards the 8.4" simply because of size and the uC graphics driver I want to use is a max 800x600 output.
    What do you guys think is the best option?
    Variable Bitrate quantum's Avatar
    Sep 2005
    SLS as in Cadillac SLS?
    7" is pretty popular, and about as small as I'd go. You can probably fine one wth the same or better specs (they are specs for a reason).
    If it is a Caddy, I had a 7" in mine NP. 8.4 was a tad too big, but anything can be done with enough time and cash.
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Where did you find a 6.5" with NATIVE 1024x768 resolution ?
    Jan 2006
    Quote Originally Posted by quantum View Post
    By SLS I mean selective laser sintering, a rapid prototype process used to make one off plastic components.
    The 7" panels I looked at were all 800x480 (e.g. WVGA) or 640x480 (and not very bright). The problems with this were, firstly the manufacturer doesn't have a capacitive touch screen (which is a big must for me) available in that size. Secondly the LVDS Scaler module doesn't support Widescreen resolutions.
    And finally the microcontroller I am using to drive the primary input will only support QVGA,VGA and SVGA resoultions (e.g. standard aspect ratios). Even though the 6.5" is XGA the scaler would take care of it and it would probably look ok.
    I also looked into the 7" cased-screens available (LinITX). They were similar cost, not as bright and only had a resistive touch screen.
    Quote Originally Posted by hailrazer View Post
    Oh you know perusing through some suppliers that I use for a University project I stumbled across it.
    Think there would be interest in the community for a high-res, super bright, capacitive touch screen lcd that would fit in a double-din spot?
    Sep 2005
    Oh, THAT SLS...
    Maybe post a few links to these monitors?
    Jan 2006
    Oh, THAT SLS...
    Here are the panel datasheets:
    6.5"
    http://www.nec-lcd.com/en/products/nl10276bc13-01c.html
    8.4"
    http://www.nec-lcd.com/en/products/nl8060bc21-03.html
    the capacitive touch screen+controller, LVDS controller, backlight controller are all sourced from different companies.
  1. 8.4" fujitsu touch panel -- need pinouts, any ideas?
    By ShinkunoNamida in forum LCD/Display
    Last Post: 05-09-2009, 03:52 AM
  2. Who has an 8.4" screen?
    By guitar333 in forum LCD/Display
    Last Post: 08-01-2003, 04:07 PM
  3. FS: DennisK 8.4" 12bit Touchscreen. $300.00 shipped to US.
    By LESLIEx317537 in forum Classified Archive
    Last Post: 07-20-2003, 10:58 AM
  4. Replies: 1
    Last Post: 05-28-2003, 11:55 AM
  5. Replies: 2
    Last Post: 01-17-2003, 11:16 AM
