Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 114
Thread: double din frame for the eby701
  1. #101
    sdh
    sdh is offline
    Jan 2009
    Quote Originally Posted by Slate View Post
    My 2008 629GL is 165x104mm.
    I also have the Bybyte frame, and everything fits together really well. It definitely seems like the frame is taller than the standard double din size, but in my case it is ok. The bottom part of the frame sits behind the plastic of my dashboard, but the entire screen is still visible.
    Is it possible to share the display make and model.
  2. #102
    Dec 2006
    Austin, TX
    Quote Originally Posted by sdh View Post
    It's a Lilliput 629GL-70NP/C/T
  3. #103
    sdh
    sdh is offline
    Jan 2009
    I did not mean this. The LCD module make and model once you have opened the casing. Is it Hitachi or Sharp or some other make and the model number. Thanks in advance.
  4. #104
    Dec 2006
    Austin, TX
    Innolux AT070TN83 V.1
  5. #105
    sdh
    sdh is offline
    Jan 2009
    Slate, Perfect. Thank you so much.
  6. #106
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    Sorry for my english, I write from Italy. I have received the kit from bybyte today. I have an old 629GL (perhaps 2005):
    1) The model is 629GL-70NP/C/T
    2) The LCD Panel is Hitachi TX18D11VM1CAA
    3) The main board has 2 labels on it 05-07-15 (the date ?) and 629DC2
    It will not fit. The panel is a couple of millimeters tall and the mainboard doesn't have the holes for screws allined with the frame.
    In the bybyte advertisement, it is written than the frame is for the new model (2008) of EB701 and for the 629GL. I think they have to specify better that also the 629GL MUST BE the new model!As result, I broken my flat cable and now I have a monitor just for the trash!
    As I can I will post some pictures of the components.
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
  7. #107
    Sep 2008
    Here is a picture of mine, quality is good... but dont buy if you have the same model as me, its Eby701 bought in 2008, saying led... but its not, i had to mod sand and cut the hell out of it..
  8. #108
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    I have the same model. I was just about to find out the hard way. thanks for posting. and I bought mine in mid 2008 . Aint that a butch
  9. #109
    May 2009
    So has anyone tried the new ABS frame on a new LED EBY701 with pics? Im considering buying this setup.
  10. #110
    Sep 2008
    I have the same 2008 model. I bought a plastic one and had to cut it up as well as it doesn't quite fit like bybyte says it does. It also doesn't fit into a double din like they said. I cut my metra kit up and made a puzzle out of the whole thing then glued into place. Then I bondo'd the whole thing to make it look like one piece. Now it looks 10 times better than it would have if it were all plug -n- play so I'm glad i did it. I'll post a pic when I'm done.
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 09:48 PM
  2. LCD frame sizes for Double DIN install
    By affa in forum LCD/Display
    Last Post: 11-11-2007, 09:51 PM
  3. 2 Single DIN units in a Double DIN mount
    By Dondro in forum Newbie
    Last Post: 06-22-2007, 02:21 PM
  4. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 01:19 PM
  5. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
