Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 114
Thread: double din frame for the eby701
  1. #31
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    I went for the plunge and bought one just now. $66USD inc. shipping ($70AUD for me).
    Will post up installation pics and thoughts.
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
  2. #32
    Banned
    Jan 2008
    Nice pics. Once they come out wih a solution without using double sided tape, then I will use them. I don't believe in breaking the TS in order to remove the screen from the bezel. This is mainly important if using a tranflective screen
  3. #33
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    Is that a shot at my cracked screen?
    My cell phone was sitting on a shirt on top of my printer above my desk and it slid off and landed oh-so perfectly on my screen and cracked it. Oh well.
    If you have a WRX then you can buy a double din kit for it at the mp3car store -- specifically for the rex. I'm not sure on the double-sided tape issue though.
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
  4. #34
    Banned
    Jan 2008
    Yeah, I know the DD for the WRX, but that thing i a little on the expensive side.
  5. #35
    Aug 2004
    Bundaberg QLD AU
    What screws/bolts did everyone use to mount the circuit board? the original screws used to mount it in the stock case are too small to fit into the holes in the 3 tabs behind the screen.
    Do i need to add anything to insulate between the circuit board and the tabs?
    Also how are you supposed to mount the ir sensor in line with the lense in the panel? the screen looks like it will cover that lens plus it doesn't look like theres enough room to even mount the sensor circuit board beside the screen...???
  6. #36
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Just a word of warning to anyone using this frame. It is VERY flimsy. If you're not careful you will bend the frame, which will cause your touch screen to malfunction. The other issue is that the frame isn't a true double-din size, it's close but you will need a trim ring. The mounting holes are an issue as well, as they don't match double din standard either.
  7. #37
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    you do know that it does require a DD mounting kit to fit a DD hole right?
  8. #38
    Jun 2007
    Very aware, which in the case of my specific vehicle, this frame is not a good option.
  9. #39
    Apr 2007
    Edmond, Ok
    what is your vehicle?
  10. #40
    Jun 2007
    06 Nissan Xterra
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 09:48 PM
  2. LCD frame sizes for Double DIN install
    By affa in forum LCD/Display
    Last Post: 11-11-2007, 09:51 PM
  3. 2 Single DIN units in a Double DIN mount
    By Dondro in forum Newbie
    Last Post: 06-22-2007, 02:21 PM
  4. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 01:19 PM
  5. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
