Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 114
Thread: double din frame for the eby701
  1. #41
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    Replacement Touchscreen installed, and LCD mounted to ByByte Frame:
    Now to find out how to mount the buttons so the IR receiver still works within reason. The pre-made hole for the IR is covered by the screen so I need to figure out if it will still work somehow. Need a new button battery though for the 'mote though.
    I wonder if I'm going to need a double-din kit in my car to fill up any gap there might be between my bezel and the LCD frame?
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
  2. #42
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by RyanB95 View Post
    Most likely yes.
  3. #43
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    @RyanB95
    Are those screws actually connected to the LCD from the board? Or are they acting as standoffs?
    What I am getting at is: How exactly did you connect the LCD and board. Yours monitor is different than mine, I am just curious.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  4. #44
    Dec 2006
    Wallkill, NY
    Quote Originally Posted by galvitron View Post
    @RyanB95
    There are 3 tabs with screw holes in them and 3 silver screws in the baggy that came with the frame. My board lined up almost perfectly with the 3 holes in the tabs, and the board is screwed directly into the tabs.
    The LCD is held on purely by the double-sided foam tape. There are tabs on the side with foam tape on them also. I bent those down over the LCD to give it extra support.
    If I didn't answer your question enough then I'm not quite sure what you're asking. Perhaps more pictures would help?
    Most likely yes.
    Crap.
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
  5. #45
    Mar 2007
    Socal
    You answered my question. Thanks.
    My LCD and board are different and the holes didn't line up. But I managed to get it in there OK...
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  6. #46
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    i bent those tabs down to hold my screen in place just from the back so if i ever need to pull it out, i can without shattering the screen. its just sitting in my box of carputer parts, so its not really testing out the durability of that method sitting in a box. ill let everyone know how it goes once i get all my interior peices to install it.
  7. #47
    Aug 2004
    Bundaberg QLD AU
    I emailed the support for ByByte about how to mount the 701 to the frame about a week or two ago and still haven't heard anything from them :-S
  8. #48
    Apr 2005
    im looking to purchase this for my lilli 619. does anyone know if there is any difference between the 619's and the 629's?
    does anyone here use this mount for a 619? did you get it to work without modifications?
  9. #49
    Apr 2005
    answered my own question with the search button.
    *bangs head on desk*
  10. #50
    Mar 2007
    Socal
    I drilled/tapped mine out for a Commell LS-372 and a DSX12VD and it worked great:
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 09:48 PM
  2. LCD frame sizes for Double DIN install
    By affa in forum LCD/Display
    Last Post: 11-11-2007, 09:51 PM
  3. 2 Single DIN units in a Double DIN mount
    By Dondro in forum Newbie
    Last Post: 06-22-2007, 02:21 PM
  4. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 01:19 PM
  5. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
