Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 114
Thread: double din frame for the eby701
  1. #51
    Nov 2007
    here is mine installed...
    [media]http://www.youtube.com/watch?v=rROfdnrenzY[/media]
  2. #52
    Dec 2007
    Very nice kevin
  3. #53
    Nov 2007
    the frame is actually pretty sturdy... but you have to bend the connector a bit to make it fit... i was kind of weary at first doing this but its not that hard......
    ONE ADVICE..... for anybody who is getting this.
    MAKE SURE TO TAPE THE TS SCREEN TO THE MONITOR SECURELY... because a few hours in intense heat will melt the four clear tape and it will fall right out of place.... it would be really hard putting it back since you have that double head tape around the rim of the ts screen... just my 2 cents.. happen to me a month ago now i got to take it apart to find a way to retape it without making it look weird..
  4. #54
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    ok, now i am having trouble getting my monitor cable to plug in. there ust is not enough room for that connector. even without the plastic surround. how did yall over come this?
  5. #55
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Regarding the note about the tape, I should note that in the pic above I hadn't even removed the backing from the double sided tape yet. When I did, it was very "tacky"" and seems strong. I also used the little bendable supports to support the LCD and not the controller board. The controller board is supported by a small flap of metal and electrical tape. If it falls loose, it wouldn't hurt anything because of the cables and what not.
    @americasfuture, can you post a pic of your connector? It seems to be different than mine because I didn't have any issue.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  6. #56
    Apr 2007
    Edmond, Ok
    yea ill put one of mine up when i get home later
  7. #57
    Nov 2007
    just remove the white plastic convering and bend the metal piece until it fit... it wouldnt damage it.. i had this problem too and i look on there site and it seem like they bent it...
  8. #58
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    question, what screen are you guys using ? Liliput? what do you do with the buttons?
    from my understanding from what i read in another thread, you remove the front bezel of the touchscreen and the buttons has a separate circuit board that u can move? is this true. Im just doing lots of research before i undertake a carpc.
    the double din bezel and screen looks great.....keep up dah good work.
  9. #59
    Mar 2007
    Socal
    I used a Lilliput for mine and I think that is what everyone is doing. My Lilli has a small white ribbon cable that connects to a small circuit board with the buttons and IR sensor on it. The ribbon connects via a small connector that you can unclip to disconnect the ribbon cable.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  10. #60
    Apr 2007
    Edmond, Ok
    the frame is for the screen in which the thread is titled. the eby701 by lilliput.
    you remove then entire screen assy from its plastic casing. the button panel with the remote sensor built in is placed on the back power board. it is recommended that you cover all the back of the button board with some electrical tape. but i would choose a better screen with a respectable double din screen frame to use. its going to cost you.
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 09:48 PM
  2. LCD frame sizes for Double DIN install
    By affa in forum LCD/Display
    Last Post: 11-11-2007, 09:51 PM
  3. 2 Single DIN units in a Double DIN mount
    By Dondro in forum Newbie
    Last Post: 06-22-2007, 02:21 PM
  4. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 01:19 PM
  5. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 03:54 PM
