Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 114
Thread: double din frame for the eby701
  1. #61
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Quote Originally Posted by RyanB95 View Post
    Got mine today - Looks like a real quality product if you ask me. Came in nice packaging and whatnot. Here's some pictures:
    Red strips are double-sided foam tape to better secure the Touchscreen:
    Side shot:
    LCD held in place, looks like it will be a nice fit:
    Back side:
    Came with all screws necessary plus some extra tape:
    And lots of business cards:
    I'll post some more pictures once I get my replacement touchscreen in. It should be here tomorrow so I should have pictures up tomorrow.
    I'm happy with it so far!!
    what screen is that? and where are the buttons....where is the vga connector ?
  2. #62
    Aug 2007
    Queens, NYC
    Quote Originally Posted by americasfuture2 View Post
    the frame is for the screen in which the thread is titled. the eby701 by lilliput.
    you remove then entire screen assy from its plastic casing. the button panel with the remote sensor built in is placed on the back power board. it is recommended that you cover all the back of the button board with some electrical tape. but i would choose a better screen with a respectable double din screen frame to use. its going to cost you.
    thanks ...would you recommend the lili 629 and would it work with this din frame. it would make life a little easier for me if this frame would work.
    i also saw on bybyte.com that they have the eby701 mounted and selling with the frame ...but you would recommend a better screen?
    edit: never mind about the 629 i see that bybyte has one for the 629
  3. #63
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    i ordered a 629 mounted inside a Mazda3 dash kit from them. I haven't installed it into my car yet, but it looks great and works well on my testbench.
    The frame feels solid and there isn't any "wiggle" on the monitor parts, despite being held in place mainly by double sided tape.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  4. #64
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    Quote Originally Posted by chris350 View Post
    It's a Lilliput EBY-701. The button board and main circuit board aren't connected/shown in those pictures. That's why they're missing.
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
  5. #65
    Sep 2007
    Sunny Florida
    I don't mean to bring up an old thread but I just got mine the other day and everything bolts in perfectly. The only problem I see is getting the main cable to fit into the circuit board. The power cable has plenty of room but the big white connector doesn't seem to have enough room how did you guys solve that problem?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    You need to cut off the strain relief. Carefully of course.
    Take a look at this if you're not sure what I'm talking about or how to do it: http://www.mechatroniks.com/wrx/lili629-2008.html
    This is what you want to do:
  7. #67
    Sep 2007
    Sunny Florida
    I did that but it still doesn't fit
  8. #68
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    i still think this was a good idea and attempt, but bad detail in the design.
  9. #69
    Sep 2007
    Sunny Florida
    The cable doesn't fit even when you take the support off. I made it fit I just zip tied the circuit board to the mounting kit. I guess it will work like that but it would have been nice to secure the board down. All in all I guess the kit isn't too bad. I did try to remove the screen after it was taped down and it cracked like it said it would.
  10. #70
    Dec 2007
    Rochester Hills, MI
    Does anyone have a picture of what this looks like once inserted into your car's double din slot? Do you still use something like a metra kit in front of this?
    EDIT: Yes you need something like a metra kit in front of it.
  1. Available Double Din Frame?
    By fenderbender in forum Fabrication
    Last Post: 11-20-2008, 10:48 PM
  2. LCD frame sizes for Double DIN install
    By affa in forum LCD/Display
    Last Post: 11-11-2007, 10:51 PM
  3. 2 Single DIN units in a Double DIN mount
    By Dondro in forum Newbie
    Last Post: 06-22-2007, 03:21 PM
  4. Double Din Case - No Monitor
    By thwack in forum Fabrication
    Last Post: 06-12-2006, 02:19 PM
  5. Question on double din
    By jdiazj1 in forum Newbie
    Last Post: 02-08-2006, 04:54 PM
