Results 1 to 3 of 3
Thread: 700IDT spring problem
    May 2008
    I just received my new 700IDT display and the screen wont stay latched. I push it all the way in and it hits the back and comes right back out again. I have used varying degrees of pressure to try to get it to latch and I have only been able to successfully get it to latch a couple of times after spending about 5 minutes on it. Anyone know how to fix it? I would rather not RMA it just for the latch, but I need it to stay latched when not it use.
    May 2008
    Never mind I fixed it. The spring on the bottom kept getting jammed so it wouldnt properly catch.
    Low Bitrate raggaman's Avatar
    Feb 2006
    Phoenix, AZ
    Hey I am having the exact same problem. Do you mind explaining how you fixed it? RMA crossed my mind but if I can fix it then why bother. THX in advance.
    Oh why do I spend so much time and money on a technology that works only half the time? Is always a work in progress? Is never complete? I wonder.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. FAQ: How to install a DVD R/RW in your Xenarc 700IDT
    By cdcamaro9534 in forum The FAQ Emporium
    Last Post: 12-10-2007, 12:34 PM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 07:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 10:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
