Hey Dan,
You should be able to remove the sensor from the board and extend it out using some hookup wire (but I've got some ribbon cable on hand I will use).
Some of these modern boards use a really hard to melt solder and I have not tried removing the sensor yet. If I have too many troubles, I'll just snip the legs off as they are plenty long enough to still solder on to. Make sure you use a heat sink when soldering. If I don't relocate the buttons, I was just going to put a cross brace from one side of the LCD Frame to the other behind the monitor and mount the daughter board off it.
I'll be catching up with a mate who is interested in seing my setup who is an electronics engineer in the next week or so, it would be good to find out if it is possible to extend the LCD on the
power button as well to give a visual indication of what is happening, that is way out of my league, but one of his employees is a wizard at fine soldering he tells me, so maybe I will be able to call in a favour.
It would be good to post the link to ebay on this thread for others to find.
Have a good holiday, I'm planning my next one
