Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 147
Thread: UPDATE #2: TM-701l; Touch Panel Kit; "Xenarc" look inside
  1. #61
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    wow! for a minute there i thought ski**yboy was back...
  2. #62
    moahdib's Avatar
    Jul 2000
    Any update on the touch overlay installed on the NECVOX DA-7169??
    This is exactly what i need to update my system.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  3. #63
    Low Bitrate Glyn's Avatar
    Apr 2002
    North Wales, UK
    I'm also want the motorized touch setup, so when you try it out, if it fits, and the control board hides away out of sight, don't bother removing the touch panel, I'll buy it complete.
  4. #64
    Dec 2002
    Hi Armen, happy new year to you!
    Any idea on the arrival date of the test Xenarcs? I'm not hassling, just need to schedule project time!
    Now away again til Monday 6th...
  5. #65
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Originally posted by ddt
    Heh, I ordered one 2 or 3 weeks ago though. I'm not a traitor... just impatient. Plus I can actually use a carputer in my line of work. Trust me... it's a hell of a lot easier than driving with a keymap in my lap now!
    It'll be even easier when I get a touch panel.
    In case I didn't mention it before... thanks for having this done. You have done a lot for the scene just by doing this... and selling LCD's that won't break the bank is definatley cool too.
    Having said that I do feel bad for not ordering from you now!
    No problem at all, enjoy the monitor . I used to be Driver myself so I know exactly what you talking about.
  6. #66
    Sep 2002
    ILLINOIS
    7" Touch Panel is too big for the DA-7169 Housing, it doesn't fit. I am sorry guys
  7. #67
    Oct 2002
    Greensboro, NC
    so are the touch units for the TM-701L ready for purchace
    DigitalDub
    1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
    Audio
    Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
  8. #68
    Sep 2002
    ILLINOIS
    TM-701L Touch Kit
    I am finally done negotiating with the manufacturer about the kit and finally I can say that the order has been placed and money sent. It will probably be another week or so before I can start shipping your orders.
    Language barrier has been the biggest problem I had during the negotiation phase of this project. After I posted all the info and prices about the kit, I learned about a “tooling charge”. It is a $1500 charge that is added to all custom orders, so if I need to change any of the sizes for the touch panel I have to pay the tooling charge.
    Fortunately the 7” panel that they already made for another order fits perfectly in the TM-701L Housing (outside dimensions) and that is what I am ordering. This is the only way to avoid the tooling charge.
    Problem: The only problem with this panel is that the Active area is a little bit bigger then the inside frame of the monitor. When the panel is installed the inside frame presses on the panel and the pointer stays in one place.
    Solution: I used a spacer (cardboard frame .5mm thickness) between the housing and the touch panel and it works like a charm. Here are a few pics (click to enlarge):
  9. #69
    Sep 2002
    ILLINOIS
    Touch panel thickness is 1.1mm + Cardboard spacer thickness is .5mm so a total of ~1.6mm. The front half of the monitor housing has 2 tabs that hold the insides (LCD panel + controller) on top side of the housing, they needed to be adjusted (with a dremel) a little bit to fit an extra ~1.6mm. Here are a few pics of that (click to enlarge):
    Here are a few pics (56K Warning) of the panel installed (click to enlarge):
    Side by Side
    Guess which one has the panel installed:
    These and other pictures can found Here. Let me know what you guys think.
    Thanks,
    Armen.
  10. #70
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Well I'm not a driver by profession, my work does require me to drive a lot though.
