Results 1 to 10 of 15
Thread: EBY-701 button board
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    Does anyone know where I may be able to get a replacement button board for the EBY-701? I checked digitalww and the mp3car store, neither has it.
    Any chance a 619 or 629 board will work?
    Thanks!
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
    Dec 2006
    Wallkill, NY
    No one?
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
    Dec 2006
    Wallkill, NY
    No one knows? I really need a new button board as I fried my IR sensor section of the board and need to have the IR sensor working. Thanks.
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
    Vendor - Qube colin's Avatar
    Dec 2006
    Man, you don't need a new board if you just fried this sensor.
    For the record, its next to impossible to fry an IR detector unless you've been modding it and ran it out of specs, but typically they shouldn't die.
    What makes you think its the IR sensor?
    Dec 2006
    Wallkill, NY
    No, I didn't fry the IR sensor itself... I destroyed the board using a soldering tip that was too big. I actually disconnected the leads in the board. Perhaps some pictures will help:
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
    Dec 2006
    Wow, that's dirty.
    First off, I don't know where you can get one of these button boards.
    With that said, I'd suggest that you hack it up a bit more, what do you have to lose? Buy a smaller tip ANYWHERE and it'll cost you less than the shipping cost of a new board. Then use a knife and cut the traces, etc etc etc. All IR sensors are the same, VCC IR GND (no particular order) so if you can find a vcc point you should be okay...
    Why spend the money?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Yeah, just use a knife and scrape the green stuff off till you see a nice copper spot to solder to for each point. The ground plane above it, the trace on the side, and maybe the 3rd is on top? Just use some solid wire like a resistor lead or glue it down well because if it pulls it will rip the traces off the board.
    Low Bitrate dLockers's Avatar
    Jul 2007
    I threw my eby701 out the other day, otherwise you could of had it with the extended IR port already
    Low Bitrate deeznudts's Avatar
    Oct 2007
    Trenton, NJ
    I have one PM me and we'll work out the detials
    Dec 2006
    Wallkill, NY
    PM sent
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
  1. Change Log
    By iamgnat in forum CarFrontEnd
    Last Post: 03-19-2008, 10:33 PM
  2. iGuidance Hacks
    By pbarrette in forum GPS
    Last Post: 12-28-2007, 03:06 PM
  3. Vista Ready board does not see XP only peripherals
    By jdiazj1 in forum General Hardware Discussion
    Last Post: 06-05-2007, 09:57 PM
  4. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 10:43 PM
  5. Determining button highlight order
    By parksgm in forum StreetDeck
    Last Post: 12-19-2006, 10:38 AM
