Results 1 to 10 of 17
Thread: SpySupply's Ultrabrite Upgrade?
    Dec 2002
    Hello,
    First post here. I am looking into purchasing a xenarc vga + touchscreen. Spy Supply offers an ultrabrite upgrade for the xenarc LCD's. I'd like to find out:
    1) What they are doing to increase the brightness?
    2) Is the screen backlight running outside its rated specs?
    3) Is it worth the upgrade price for outdoor use?
    4) I am very comfortable around anything electronic, is this something I can do myself?
    5) I have heard other people say they added a second inverter to increase the brightness of their LCD screens, how exactly is this wired up? Did the screens have an extra connector for a second inverter?
    Thanks for everyones help.
    Alex Lear
    Nov 2002
    Berkshire, England
    very interesting, if anyone knows about this I'm also very interested.
    Sep 2000
    LA, CA, USA
    Bump for more ideas, information, thoughts.
    Anyone want to hook up another invertor to their Xenarc backlight?
    VENDOR - SpatialMinds millec's Avatar
    Dec 2002
    Mt. Vernon, WA
    Spy Supply's Ultrabrite Upgrade
    Bump.
    Anyone have this upgrade? How do you like it?
    Any reports on the Xenarc's visibility in general (inside a vehicle). Is this really a necessary upgrade, or is it OK stock.
    --Craig
    Jul 2001
    Dallas, TX
    I have to admit, the Xenarc is a little difficult to see in my car when the suns out... Not impossible, but is a little frustrating.
    I emailed Spy Supply about the Brightness upgrade, apparently it's not something you can do yourself. Too bad, I'll have to buy another unit to get it...
    Brian Cozzens
    Duke Nukem Forever / Max Payne
    www.3drealms.com
    May 2000
    Ft Gordon, GA
    could someone post a link to this? thanks,
    Etrik
    "if everything is under control, you're not going fast enough!"
    Dec 2002
    Mt. Vernon, WA
    Here are the links to the monitor. You might also want to read the sticky Xenarc FAQ post in this forum. Among other things, it mentions a $20 discount on these monitors from Spy Supply.
    http://www.spysupply007.com/LCD_Scre...arc/700TS.html
    http://www.spysupply007.com/LCD_Scre...rc/700TSV.html
    --Craig
    Sep 2000
    LA, CA, USA
    Well....if i was spy supply and i was selling ultrabrite upgrades for $195 then i wouldn't tell you that you could do it yourself either, even if it was the easiest thing to do in the world.....but that's just me. heh.
    I think the best possibility for information would be xenarc. They might tell you their inverter specs and share the specs of the backlight in that panasonic screen.
    Sep 2000
    LA, CA, USA
    Well I hope someone can read Japanese because here is the spec sheet for the LCD panel but it's written in japanese.
    Specs
    Jan 2003
    nice spec sheet. bout don't see anything on the backlight. i doubt the mod would be that difficult and that costly. most likely its a translucent screen with a light source on the side (top & bottom or side to side) this method is very common with backlit screens due to cost and power drain.
    So, it should just be a matter of switching out the light source.
    Has anyone got the upgrade? If so would you mind opening it up and checking for us
