Results 1 to 7 of 7
Thread: Component to VGA? & Composite to VGA?
    May 2002
    I need a component to vga adapter. Anyone know if i could build one or get an inexensive one. An also need a composite to vga maybe an adapter that has both.
    Dec 1999
    Buena Park, CA
    I think the cheapest solution you're going to find is from Viewsonic. They have an adapter that takes regular video sources in and upconverts them for viewing on PC monitors. I don't think it takes component video though. And what are you using with component ouputs that you want to see on a VGA display? What type of display is it? If it is a multiscan display, it may be compatible with a simple component to RGB adapter (although most of the ones that I know of are expensive professional units).
    May 2002
    is rgb the same as component its for the xbox and hdtv
    Dec 1999
    Buena Park, CA
    No, RGB is different, but easily derived with a matrix circuit. The problem is the matrix circuits are usually built into the displays, and are rare to come by externally. Extron (www.extron.com) makes one, but it retails for about $900.
    Dec 2001
    Columbia, Maryland
    there are some products by audio authority, its called a component transcoder which converts the component signal to RGB-H-V. those run around 150 or so.
    May 2002
    And how do i get that to vga?
    Dec 2001
    Columbia, Maryland
    well RGB-H-V is the signaling on VGA, its just split up onto 5 BNC (some models might be db-15 out) connectors instead of a db15 connector.
