When you take a flashlight and see the image your right and the display is ok and the backlight is bad. If you put a multimeter between the 2 leads from the backlight (the ones who run from the inverter) be carfull because the voltage is verry high (KV).
And you don't want to tough that.!!!!!!!!!!!
LinkBack URL
About LinkBacks
