Results 1 to 10 of 13
Thread: Just how much of a pain are the touchscreens?
    Jun 2007
    I'm in the planning stages of my main project car right now and I'm just trying to figure out the general plan. What I'm wondering is how easy is it exactly to maneuver a touchscreen while you're driving in a car? I would guess it'd be damn near impossible. What I'm thinking is that I could just go with a trackball mouse and a keyboard for an easier to use interface. The keyboard obviously wouldn't really be for driving use unless by the passenger but the trackball would be my main point of interface.
    So I'm just curious on what some of you have to say, obviously the other benefit is that non-touchscreens are going for pennies now that everyone is all about the touchscreens.
    May 2006
    Calgary, Alberta
    With a touchscreen the buttons are always in the same place. So if you want to change the track of volume, you know where to put your finger and only have to glance once to make sure you're hitting the right spot. With a mouse, you have to move it and then glance to see how close you are. Then move it again and keep doing that until you're on the button you want. Too much hassle for me.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jul 2006
    seattle
    both are too dangerous.
    I never touch the touchscreen while driving.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    i wouldnt try browsing windows folders etc while driving thats just asking for a darwin award.
    my audio player skin has big buttons and limited functions...
    anything more than next track or pause, its too much while driving.
    the touch screen is great if used with common sense
    Mar 2006
    Colorado, but Canadian!
    I have no problem navigating my touchscreen and I can do it without staring at it. The same amount of concentration used to glance at a normal HU really. Mouse/Trackball is waaaaaaay more dangerous.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    i should add that I plan to have a transport button pad molded into the center console as well so simple functions such as starting and stopping and changing tracks will be handled by that. So basically the exact same as I do with my remote for my headunit now.
    Jun 2005
    chicago, Illinois
    If you are using a front end, which you should already be considering doing so, navigating through the menu screens is easy while driving because they have large buttons and in some cases gestures. And the front end useally has only the functions you should be needing while driving, ie media nav etc. Navigating through your operating system is simpley reckless while driving.
    PROGRESS:
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I would plan on using multiple input functions. For instance, I use Streetdeck which uses gesture inputs (so does Centrafuse), so all I have to do to go to the next song, is swipe my finger from left to right across the screen, OR I can push and rotate clockwise on my Powermate, OR I can push the track + button on my steering wheel controls.
    Which input I use really depends on how much attention driving requires at the time. If i'm doing 70 down a road with a bunch of twisties in it, I'll feel and use the steering wheel control. If i'm using cruise control on a deserted interstate, I'll take my eyes off the road for a second or two and use the touchscreen.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Mar 2005
    Quote Originally Posted by 2k1Toaster View Post
    True. Touchscreen I can do w/o looking it is easier than my HU.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I've incorporate my vehicles stock steering wheel controls........best input method!
    Other than that (hard buttons somewhere), touchscreen is the only thing you should attempt to use when driving. Even then, only for pause, play, ff, rwd, vol etc. Anything requiring you to look should be done when stopped..........
    Leonardo Da Vinci
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. Multiple touchscreens on one PC?
    By jm1133 in forum General Hardware Discussion
    Last Post: 07-02-2008, 03:45 PM
  3. Running Multiple Touchscreens
    By tschallb in forum LCD/Display
    Last Post: 03-03-2008, 08:27 PM
  4. Theory on why Lilliput touchscreens die
    By archimense in forum LCD/Display
    Last Post: 08-27-2004, 02:12 AM
  5. Replies: 1
    Last Post: 02-27-2003, 08:29 AM
