Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Lillitput 629GL-70NP/C/T 800x480 WTF is going on??
  1. #11
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    I've found that my Lilli (619) works best at 75Hz refresh rate. You may want to go to "List all modes" and set it to 640X480, 16 bit, 75Hz.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #12
    Apr 2006
    Sydney, Australia
    Sweet, ok, so the higher the freq the better?
    Now I'm just waiting on the board manufacturer to come up with the correct BIOS settingd for the display and see what the results are.
    Cheers
    New Car PC Build list in progress
  3. #13
    Mar 2007
    Socal
    I honestly don't think the BIOS setting will help as it doesn't control the display under windows. So is your graphics device an onboard? If so, is it Intel?
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  4. #14
    May 2006
    IL.
    Try VGA drivers from this site: Commell.
  5. #15
    Mar 2007
    Socal
    So I looked up your motherboard and I see that it is a Intel® 945GM (actually a nice little board!). And you should have no problem (other than the work involved) creating a driver using either IEGD gold or the regular driver. Or you can try powerstrip.
    The process is all laid out in that 945 800X480 thread. In fact, I posted a DTD string for a Lilli 619 a while back in that same thread that should get you started.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  6. #16
    Apr 2006
    Sydney, Australia
    Kewl, I'll be trying a few things over the weekend.
    So do you think I should use another mainboards driver?
    Quote Originally Posted by AXm77 View Post
    Mm, I'll try em
  1. 800x480 on a transflective lilliput?
    By kuo in forum LCD/Display
    Last Post: 12-24-2007, 01:06 PM
  2. Has anyone EVER gotten a Lilliput to detect 800x480?
    By larry_llama in forum LCD/Display
    Last Post: 12-03-2006, 03:05 AM
  3. 800x480 on the SP13000 with Powerstrip
    By theminor in forum LCD/Display
    Last Post: 10-16-2006, 11:32 PM
