Results 1 to 5 of 5
Thread: Help with DennisK setup
    Oct 2002
    Georgia
    I just got my DennisK setup, and I am trying to see if anyone can help me out.
    DennisK is helping me trying to figure out what is wrong, but I just wanna ask the public and see what they know.
    First off I have seen the threads about changing the Hirose cable connection to fix the colors but I dont think my controller card is the same as those. IMG:
    http://www.evdisplays.com/tallon.htm
    Also here is an image of my hirose cable:
    And then here are the pictures of the crappy video quality I have been getting. Be prepared to shield ur eyes.
    I have tried every possible setting on the LCDs RGB color sliders in the osd menu.
    Any help is apreciated
    -Merc
    1996 Jeep Grand Cherokee
    [:::::::::.]99.9%
    Working On: Fixing wireless network interference
    Specs: 8.4inch vga touch, 1.?? ghz, 256 DDR, 4gig OS HD, 120gig Media HD, opus
    Feb 2001
    Somerville, MA
    That does look like a different board than the DennisK setup I have.
    You should try to find the datasheet for the controller and the LCD. Then figure out how it is connected. The previous DennisK problem was that the board had 8 bit output for each color and that the LCD was connected to the lowest 6 bits, not the highest 6 bits. An example might help:
    Board wants to send out a bright red. In binary it is:
    11000000 = 192 (max is 256)
    The screen should see:
    110000 = 48 (max is 64)
    The screen did see:
    000000 = 0 (max of 64 again)
    So something that was red looked black.
    Hope that helps.
    Twostep
    Oct 2002
    Georgia
    Hey thanks for that info. In my first post I did give a link to the only spec sheet I could find for my controller. And here is a link to the spec sheet of the lcd.
    http://www.a2zrealty.com/sharp/lq9d161.pdf
    Now just to figure out what to do. Wanna help But until the next reply I will see what I can do myself. Uhhhohh.
    -Merc
    [:::::::::.]99.9%
    Banned outragis's Avatar
    Jul 2002
    Vermont
    I had a simular problem when I hooked up my new screen! I entered The BIOS set-up and switched to default bios settings, and it worked
    Dec 2001
    Maryland
    Did you get this email?
    A big thanks to Dennis for sending this out.
    TO all that purchased the DennisK VGA kit,
    I have been informed that the wrong hirose cable was shipped with the units. This has been corrected. I have attached the proper mapping for the cable. It should take about 15 minutes or so to re-wire. If you prefer, I can ship the correct cable to you. If you elect to have me ship the cable, please send the old cable back to me when you receive the correct cable. Please ship to:
    European customers do not have to ship back the cable.
    In addition, in some cases, the panel will not display full screen during dos, or on boot up. This too has been corrected with an updated bios. I can send the bios to you and you can plug it into the Talon VGA controller.
    Please advise me on what, if any, parts you would like me to send to you.
    I am sorry for this inconvenience. The display looks great with the correct hirose.
    Cable:
    TALON CABLE MAP
    SHARP LQ9D161 VGA PANEL
    Pin # of LQ9D161 P3 (32 Pin) P4 (28 Pin) Pin Description
    1 25 R0
    2 4 GND
    3 26 R1
    4 14 VSYNC
    5 27 R2
    6 15 HSYNC
    7 28 R3
    8 12 GND
    9 8 GND
    10 20 CLK
    11 32 G0
    12 11 GND
    13 1 G1
    14 N.C.
    15 15 GND
    16 N.C.
    17 2 G2
    18 N.C.
    19 3 G3
    20 13 GND
    21 22 GND
    22 25 VCC
    23 7 B0
    24 26 VCC
    25 8 B1
    26 N.C.
    27 29 GND
    28 16 ENAB
    29 9 B2
    30 22 GND
    31 10 B3
    CABLE MAP FOR CXA-L0612A-VJL INVERTER
    Pin # of Inverter P2 (5 Pins) Description
    1 1 12 V
    2 2 GND
    3 5 Vrmt
    4 3 0 to 4V(Brgtnss)
    5 N.C.
    2004 F350 Ext. Cab
    System not reinstalled in it yet
