Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Xenarc loosing screen posistion
  1. #11
    Jun 2007
    Oxnard, CA
    Same problem... had to solder some push switches in. Just be sure to test with a meter first. Those Tactile switches are kind of weird at first.
  2. #12
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I dont think its a problem with your Xenarc. I have the M10000 board and have had this problem myself with a k301 screen.
    There are two different locations on the VIA site to download two different, but compatible display drivers for the m10k.
    http://www.via.com.tw/en/index.jsp
    Under the "Support" tab, you can get drivers from "Drivers at VIA Arena" and "EPIA/VB Downloads". Try the two different drivers. Thats how I fixed my problem.
  3. #13
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    It's definitely the screen. This problem has happened to many xenarcs. It's a problem with the internal LCD controller. You can purchase a new controller board from xenarc if you are outside your warranty. If I remember correctly, it's $105. I got a new board and my problem went away.
  4. #14
    Dec 2006
    The refresh rate bump from 60 to 75hz definetely centered it and so far about 10 starts later, no problems.
    Hate to say it, but I never had problems like this with the 10+ lilliputs I've always installed in the past. Love the image clarity of the xenarc, but not worth it when it keeps giving me problems like this. Shouldn't have to "fix" such basic items. (spent DAYS figuring out bios settings to make it work intiially)
  5. #15
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Guys - just to let you know I have the same problem with a Via 12000 ( S3 Video ) and a Cartft.com TMR which I think has common parts. I'm running at 60htz but after reading this I'll bump it up and see if that fixes the problem.
    Cheers
    Terran
  6. #16
    Dec 2006
    Okay, problem came back today, and is desperately annoying. Will try the drivers change later this weekend.
  7. #17
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Just wondering...is the temperature low recently? I would only get this problem on my m10000 at temperatures below 10c. Good thing changing the drivers fixed it though.
  1. XENARC 700IDT touch screen menu
    By funky in forum LCD/Display
    Last Post: 02-22-2007, 10:19 AM
  2. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 10:15 PM
  3. Help/Questions with my Xenarc screen
    By SnyperBob in forum LCD/Display
    Last Post: 05-25-2005, 06:39 PM
  4. Question about Xenarc screen
    By Obsolete in forum LCD/Display
    Last Post: 05-25-2005, 10:41 AM
  5. Replies: 1
    Last Post: 05-01-2005, 12:25 AM
