Results 1 to 10 of 17
Thread: Xenarc loosing screen posistion
    Jun 2007
    Oxnard, CA
    Hello,
    I have not had much luck finding a fix for this on the forums or Google, hoping someone else might have had this problem already.
    My Xenarc has been (to me, randomly) loosing its horizontal positioning when booting into the OS (WinXP).
    Usually this does not happen, but some days when I turn the car on, POST and the bootup logo are fine but as soon as the GUI comes up, the picture is moved to the right greatly.
    At the moment, I just go into the screen settings (with my soldered on buttons hanging out the bottom of the screen) and select the "Auto Adjust" and I am ok for a few days until it happens again.
    Has anyone else experienced this or have any suggestions?
    Thanks,
    Low Bitrate raggaman's Avatar
    Feb 2006
    Phoenix, AZ
    Unhappy
    I get the same thing. Don't know why or how to fix it.
    Oh why do I spend so much time and money on a technology that works only half the time? Is always a work in progress? Is never complete? I wonder.
    Jun 2007
    Oxnard, CA
    Here are few more details on my setup:
    M10000 PC with VGA cable running about 8 feet.
    Problem with both intel drivers and stock XP drivers.
    Have not had this problem with any other 15"+ LCD (the on my work bench).
    Using unregulated 12V directly from car into a fused input on the Xenarc.
    Seems to happen when the PC takes too long to shutoff the and the M2ATX cuts the power off manually (but I'm not entirely sure about that...).
    Can you share any details that you have on the problem?
    Feb 2006
    Phoenix, AZ
    Well my setup is fairly new as I recently replaced pc +monitor. I have the xenarc plugged into the ciggy adapter ghetto style (why not) and whenever i return from hibernation, the screen is shifted just a bit to the left. Using the Auto Adjust feature brings it back into sync. It is nothing that I have really researched at all. I just saw your post and replied that I had the same issue. Maybe this has something to do with it http://www.xenarc.com/faq.html#QA1 . I don't have time right now to try it out. Let me know if it works.
    May 2006
    Calgary, Alberta
    Same thing happens to my Xenarc, I just use the remote to do an Auto Adjust.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jun 2007
    Oxnard, CA
    Hmm interesting, bummer, I have an integrated card that does not support 800x480.
    I am actually out of the state atm so I do not have access to my car.
    Hey Maheriano, are using an unregulated power input as well?
    (trying to identify a possible cause)
    Nov 2007
    Mine has been working consistently for 2 weeks, but it did this today. Grr.
    Nov 2007
    I changed my settings from 800x600 @ 60hz to 800x600 @ 72hz, and it's fine now.
    We'll see how long it stays fine.
    Dec 2006
    Will try the refresh rate change in the morning. I have this exact same problem, but I lost my remote, and the buttons are buried in the housing, so needless to say, it's NOT a simple 'auto adjust' fix for me but a 15 min dismantle/remantle to get the position correct.
    Help!
    Nov 2007
    I'm in the same situation actually, can't find the remote and the buttons are inaccessible.
    The 72hz rate has not been 100% reliable but it has only gone wrong a couple times since my last post.
    Gotta find my remote...
  1. XENARC 700IDT touch screen menu
    By funky in forum LCD/Display
    Last Post: 02-22-2007, 11:19 AM
  2. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 11:15 PM
  3. Help/Questions with my Xenarc screen
    By SnyperBob in forum LCD/Display
    Last Post: 05-25-2005, 07:39 PM
  4. Question about Xenarc screen
    By Obsolete in forum LCD/Display
    Last Post: 05-25-2005, 11:41 AM
  5. Replies: 1
    Last Post: 05-01-2005, 01:25 AM
