Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Installing a second monitor
  1. #11
    May 2008
    NZ
    Looks good Enforcer
    Is it much of a challenge to modify/trim a factory headrest to fit a screen? What do you use for a backing?
  2. #12
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    There is no 'backing' as such.
    Basically I have made an MDF surround which, with the leather in between, fits the monitor snuggly.
    The original inner plastic plate had to be trimmed a bit and the way the metal tube fastens onto it also had to be modified slightly, and then it was a matter of cutting out excess foam.
    I do have pictures of the process and will be doing a tutorial at some point.
    There is already a tutorial by Cris who made headrests from scratch, well worth a look
    Fabricating new headrests
  3. #13
    May 2008
    NZ
    Ok so I bought a 7" Headrest monitor that takes an RCA input (it was CHEAP!!!!). I also picked up a VGA splitter cable & then thought I'd be smart & get a VGA to RCA/S-Video cable................ I guess I'm not so smart though as the monitor has "No Input Signal". I assume that I need a VGA to RCA signal converter?
  4. #14
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by Ban_One View Post
    Yes you need a converter. look at my post above for one on Ebay.
  5. #15
    May 2008
    NZ
    Sweet!!! Thanks hailrazer
  1. computer lcd monitor in car
    By BRADMAN in forum LCD/Display
    Last Post: 09-28-2006, 04:59 AM
  2. Replies: 10
    Last Post: 08-20-2006, 04:57 PM
  3. F/S Pioneer AVH-P6400 6.5 Widescreen In-Dash Monitor!!
    By neema12 in forum Classified Archive
    Last Post: 07-11-2005, 02:12 PM
  4. FS: Full Carputer and 8" Monitor
    By mort in forum Classified Archive
    Last Post: 06-08-2005, 12:54 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
