Results 1 to 3 of 3
Thread: Xenarc component RGB input?
    Jul 2008
    I just received my 700YV but cannot seem to get the VGA input working with an RGB signal. I am using a component RGB cable from a playstation 2 through a componentRGB-to-VGA(db15) adapter cable, but the video screen keeps going to Auto off as if it does not detect a signal when on VGA source. Using the yellow composite signal works, but i would like to retain the widescreen format and quality that the component cables offer.
    Does the 700YV support a component RGB input via the VGA connector or is there another signal associated only with VGA computer resolutions that are necessary for the monitor to detect it? Thanks for your help.
    -ted
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Monitors have to be capable of SOG (Sync On Green) in order for it to run off a component to vga adapter.
    And unfortunately most Lcd monitors do not support this.
    Jul 2008
    Quote Originally Posted by hailrazer View Post
    Thanks for the reply, that's what i was looking for. Guess I will stick with composite for the ps2 and save the vga connector for a PC down the road.
    FYI, here is the response I got back from Xenarcdirect (specifically regarding the 700YV).
    We have not tested a RGB – VGA adapter for these monitors. Most likely, the adapter is not converting the signal to something the monitor can recognize. The monitor can recognize resolutions from 640x480 – 1024x768, @ 60-85 Hz. Please make sure the adapter is converting the VGA output to within these specs, or if there is no converter, that the RGB signal is within these specs.
    Xenarc Technical Support
    [email protected]
  1. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  2. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  3. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  4. All IN Wonder 9600XT Girder Component out
    By lookinco in forum General Hardware Discussion
    Last Post: 08-22-2004, 06:27 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
