Results 1 to 9 of 9
Thread: 2 Headrest Wiring Situation
    Jul 2008
    Angry 2 Headrest Wiring Situation
    So i got two headrest screens, came out of my brothers car.
    From the monitor i got the wiring
    black
    brown
    blue with another blue wire in it
    red with another red wire in it
    from my video input i have on one side the power wiring coming out and one side to monitor
    red
    orange
    black
    red wire with pink wire in it
    so the problem i have is how do i connect these wires from the monitor to the harness thing with video input
    please help me find out with wires connect to which ones!!!!
    monitors are myron and davis
    s/n 41404500492
    model : am-056PN/PP-C
    Jul 2008
    anyone?????????
    Jul 2008
    Anyone???????
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Oct 2006
    Las Vegas
    ok, it looks like you have a A/V monitor with 2 RCA...err... coaxial inputs.
    how about for the monitor itself:
    RED-12V
    BLACK-GND
    RED-inside RCA AV1(2?) Plug inner
    RED-outside RCA AV2(1?) Plug outer
    Brown-ACC?
    and that other thing... I'm guessing but:
    Red-12V- goes to red
    silver-gnd- goes to black
    Red with pink goes to one of the 2 A/V inputs outside to outside, inside to inside.
    orange??? ACC? -goes to brown?
    Something like that? I don't know for sure, I've never dealt with that brand.
    Jul 2008
    ya its not straight forward.
    there is no red coming from the monitor
    i tried to power it up but nothing
    Dec 2008
    Your AM-056PN wiring?...
    Cheers!
    Did you ever get the AM-056PN wiring identified? I have a couple of these monitors as well and I took one apart to see if I could figure out the connections, no dice I hope to use the remaining monitor w/ a color underwater camera as a fun project - trying to connect 12VDC and and RCA video signal connector - had no luck at all - perhaps you have?...
    Have a great day!
    Sailndive345
    Feb 2009
    am-056PN/PP-C wiring solution
    Hi-
    I have one of these that I just got working. First of all, the wiring colors do not map to what you would think:
    Power:
    Black: +12v
    Bare wire in outer casing: Ground
    Signal lines:
    Red: Video signal (outer wire is video signal ground)
    Blue: Audio signal (outer wire is audio signal ground)
    Unknown:
    Brown wire (just leave unconnected.)
    To figure this out, I used a variable voltage power supply and connected it to what I thought may be the correct leads and then slowly turned up the voltage while watching the current. When the current starts to increase quickly without the voltage increase then you know that this is a short and you back off before doing damage.
    The red and blue wires are coaxial and so you should never apply power to these. You may have damaged your unit but then, maybe it was protected and you are ok. You'll just have to try!
    Have a nice day!
    -S
    Dec 2008
    Unhappy
    Quote Originally Posted by Playah View Post
    Hi-
    Power:
    Black: +12v
    Signal lines:
    Unknown:
    Have a nice day!
    -S
    Definitely not intuitive... I'll give it a try; I hope I didn't fry it when I was trying random connections in frustration (I had given up on it by that time)
    Thanks!
    Sailndive345
  1. How-To: Install Large Headrest Monitors
    By Altimat in forum Fabrication
    Last Post: 04-15-2011, 01:15 PM
  2. IN-909 Headrest LCD wiring Help?
    By tbaggott in forum General MP3Car Discussion
    Last Post: 06-01-2008, 07:52 PM
  3. Wiring question...
    By atikali2000 in forum Newbie
    Last Post: 04-17-2008, 11:21 PM
  4. I have a weird wiring situation. Please read...
    By audrenaline in forum Power Supplies
    Last Post: 01-31-2004, 02:07 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
