Results 1 to 10 of 11
Thread: Lillyput EBY701 Always on?
    Sep 2007
    Sunny Florida
    I know the 619's are able to auto on I was wondering if the 701 is able to? I'm going to remove the buttons but I want to make sure that it's even possible. If not then I will need to keep the buttons or the ir port in order to turn it on. If it is possible how can it be done?
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Yes it can be done exactly the same way as the 619 and 629 - by entering the same code.
    I installed my carpc into my pet Kangaroo, mate.
    Sep 2007
    Sunny Florida
    hmm I tried that earlier and it was a no go. I entered the number and everything but it didn't give me the "--- - - - -" when I eneted 588998
    Nov 2006
    I had a 701 and it took a few goes, but did end up getting it to work. If you search for it, I think there are others who had real trouble getting to the --------- part, but they did eventually get there.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    you have to use the screen buttons, i have a 701 and i had the same problem, i can't remember how to access the menu, but once you go into the menu you can change the setting on/off
    Low Bitrate ContaiN's Avatar
    Sep 2005
    Melbourne VIC, Australia
    I have a 701, worked fine for me
    Use the number 588998, which will bring up the menu, you need to press menu again ON THE BUTTON ON THE SCREEN ITSELF, not the remote, this will take you to alt options, auto on being one of them
    May 2008
    Australia
    Question! Those with functional CARPCs, do you get the blue "no signal" screen on the lilliput after you turn your car/system on?
    Any way to get rid of that screen? Only work around I thought was making a board which waited 3-5 seconds before giving power to the screen, ensuring it has a signal and so no ugly blue no signal image..
    MX-5 Carputer Progress:
    (Check ibfragalot's Worklog)
    Purchase [****_] 95%
    Design [*****] 100%
    Install [*****] 95%
    Sep 2007
    Sunny Florida
    Quote Originally Posted by ibfragalot View Post
    Is suggested to run the screen power from the power supply on the computer. It's a steady 12v signal and is a lot safer for the screen. Plus if you run it that way the monitor wont turn on until the computer is on.
    Thanks everyone else I will give it another go when my new screen comes in. I cracked the first screen >=|
    May 2007
    i'd love to get rid of that stupid blue no signal screen too...
    Jun 2008
    Houston
    Id like it not to pop up every 20 seconds from wiggling too much...stupid lousy connection...
  1. Replies: 10
    Last Post: 05-19-2010, 11:14 PM
  2. EBY701 vs. HR702
    By yuiou in forum LCD/Display
    Last Post: 06-21-2009, 06:20 PM
  3. EBY701 Help ! Main Board issues...
    By stevey500 in forum LCD/Display
    Last Post: 05-31-2008, 05:38 PM
  4. Help Please, no display on Lilliput EBY701
    By notuptodateguy in forum LCD/Display
    Last Post: 12-26-2007, 11:08 PM
  5. replacement touchscreen for EBY701
    By FusionFanatic in forum LCD/Display
    Last Post: 12-15-2007, 06:36 PM
