Results 1 to 2 of 2
Thread: Problem with lilliput eby701 >=|
    Sep 2007
    Sunny Florida
    Okay I hooked up my screen to my workstation inside and it worked fine. I then put the screen in the car and it worked fine. Then I put the car back together and boom didn't work. So I took the car apart again and it still doesn't work. It will sometimes make it to the bios screen before cutting out but most of the time it doesn't make it that far. It will go all white sometimes or sometimes it will show a picture and then slowly fade out. I think it has to do with the ribbon cable but I've disconnected and reconnected that cable like 30 times and I'm still not able to solve the problem. Does anyone have any ideas?
    Sep 2007
    Sunny Florida
    Nevermind I figured it out. For those who might have the same problem some day I will answer my own problem.
    The ribbon cable that give the screen a signal was too tight I guess. There was some slack in the cable but it wasn't enough. I moved the circuit board closer to the screen and it worked like a charm.
  1. EBY701 Lilliput Touchscreen BROKE! Need USB controller!
    By stevey500 in forum Input Devices
    Last Post: 05-04-2008, 12:19 AM
  2. Lilliput TS problem.
    By FunkDaMonkMan in forum LCD/Display
    Last Post: 12-15-2006, 05:15 PM
  3. Lilliput Touchscreen problem
    By DookieGraphics in forum LCD/Display
    Last Post: 03-24-2005, 02:33 AM
  4. Replies: 0
    Last Post: 06-14-2004, 11:01 PM
