Results 1 to 8 of 8
Thread: Long VGA cable
    Jun 2008
    Long VGA cable
    Ok I have a Xenarc 700TS, it will be in my dash while my computer will be in the trunk. Is there a problem with running a usb and vga cable that far to hook them up? Along with that I read the FAQ on powering your monitor but the only simple way I saw was just run it through a molex on the power supply if im correct.
    Low Bitrate yaniv's Avatar
    Jan 2008
    I have a 5 meter VGA cable and an ACTIVE 5 meter USB cable.
    Sometimes I see a bit of noise on my screen but I think it's just the old computer's fault. The USB works great without problems.
    My Car PC project
    Current status: Fabricating screen
    Jun 2008
    Hmm any other care to comment , only reason I ask is I see all these setups yet noone explains the trouble with wiring it up.
    Jan 2008
    Probably because there isn't any "trouble"
    My Car PC project
    Aug 2007
    Not sure how long my cable is, probably would be 5m, don't have any issues with it. Why would they make cables that long if they knew they were useless?
    Same with USB, no issues.
    Jan 2008
    Just make sure the USB cable you get is "active" and that the VGA cable is shielded
    My Car PC project
    Newbie maddop's Avatar
    Oct 2005
    Liverpool
    same here, i've got a shielded 5m vga from ebay and 3 active 5m usb leads from amazon all working fine.
    Do get the occassion tiny amount of noise but nothing that concerns me.
    BMW E46 (year 2000)
    CARPC installed and working!!
    Nov 2007
    Brisbane Australia
    12 wire security shielded cable
    Quote Originally Posted by mdawg View Post
    I use a 12 wire shielded multi strand security cable and I run a Hami 8" Touchscreen (USB needed) the monitor power and the VGA through the one cable with no problem.
    To allow for enough conductors I run the negative for the USB and monitor power via the shield. The Hami monitor needs 8 wires to work correctly but I did connect the shields and VGA earths via it own conductor, mainly because I had one spare wire I am sure it would have worked using the shield as they are all connected together anyway.
  1. Embedding BSPlayer
    By Needstorage in forum Software & Software Development
    Last Post: 01-29-2007, 03:15 AM
  2. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 11:47 AM
  3. long 44pin ide cable?
    By Gibson99 in forum General Hardware Discussion
    Last Post: 10-12-2004, 04:37 PM
  4. Lillput- Fussy about VGA cable length?
    By live2themaxuk in forum LCD/Display
    Last Post: 08-22-2004, 08:03 AM
  5. VGA extension cable
    By Bxscig in forum LCD/Display
    Last Post: 07-29-2004, 10:33 PM
