Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Help, trying to convert AC monitor to use DC.
  1. #21
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yeah, try it that way and see if it helps. Keep the monitor outside the car, the inverter near the battery and test it out. It it is working without buzzing, move the monitor inside the car and see if it still works without buzzing.
    Want to:
  2. #22
    Jul 2008
    Detroit
    I just replaced the fuse, and it powers up!!! Phew. I am about to test it on the short leads I am making. That wire is bigger than I thought. The guy at the electrical supply said it was 0000 wire. The conductor is almost a half in thick. Is there such thing as wire too big?
  3. #23
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No, but it can be a real bear to work with. You don't need anything too big. The 4 gauge wire you had was probably just fine.
    Want to:
  4. #24
    Jul 2008
    Detroit
    Well, I hooked it up to my battery directly with the 4/0, and it still buzzes. Must be an unsuitable inverter. Crumb. I can still use it for power tools and what not, but back to square one on the carpc. Do I try different inverters? I don't think so. I will just have to buy a DC-DC and a monitor. Any small inverters, for monitor only that could be suggested? My monitor only draws 30 watts.
  5. #25
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've heard people who have gotten good results with coleman inverters.
    Want to:
  6. #26
    Jul 2008
    Detroit
    F an inverter, Imma do this right. thanks for all your help. really. guess the 15" is going on my desk next to the 22".
  7. #27
    Aug 2008
    Smile Sinewave issues
    Hey,
    Have you considered the buzzing noise is because you are using a non sine wave inverter? Try looking around for a true sine wave inverter.
    Let me know if you have any success. I Have been checking out this site for a while and just decided to join hello all!
    Just found this googling sine wave http://www.samlexamerica.com/pure_si..._inverters.htm
    True Sine Wave Inverters will:
    Allow inductive loads like microwave oven and motor driven products to run faster, quieter and cooler.
    Reduce or eliminate audible and electrical noise in fans, florescent lights, audio amplifiers etc.
    Allows accessories that are sensitive to higher harmonic distortion levels found in modified sine wave inverters to function seamlessly with pure sine wave inverters
  1. dc - ac power inverter
    By dasaint80 in forum Power Supplies
    Last Post: 12-10-2005, 03:16 PM
  2. Possible to turn a DC Toggle switch into AC???
    By Defiler in forum General Hardware Discussion
    Last Post: 07-05-2004, 08:29 PM
  3. AC or DC power supply w/ tablet pc?
    By gutterslide in forum Power Supplies
    Last Post: 04-07-2004, 03:12 AM
  4. dc or ac power supply
    By qball008 in forum Power Supplies
    Last Post: 05-16-2002, 10:22 PM
  5. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 12:27 PM
