Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Help, trying to convert AC monitor to use DC.
    Jul 2008
    Detroit
    I'm trying to run my dell 15" lcd off DC current. I was told I should be able to bypass the monitors PSU and connect DC. Can anyone help? I need to identify the PSU and check what voltage it outputs with my multimeter. I wish I would have finished my EE degree.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That's one way to do it. The other way is to buy and inverter and power it from that. Loads easier if you don't know what you're doing.
    Want to:
    Jul 2008
    Detroit
    Already have an inverter. Horrible buzzing. I'm about to buy a dc-dc power supply for pc. Would love to run monitor off DC as well.
    Jul 2008
    Detroit
    Am I way off?
    Jul 2008
    Detroit
    another thought, if that IS the dc out, would grounding the (-) improve the buzzing when running through an inverter?
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Not the DC out.. Don't ground that.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    That spot you circled is the bridge rectifier. It is where AC is converted to DC but that is not the regulated DC out. What is the voltage you read there when the monitor is on?
    There is also a good possibility that several different DC voltages are required. It looks like there is more than one regulator after the bridge.
    ~Jimmy
    Jul 2008
    Detroit
    I will check the voltage when I get home. Thank you very much for your help. And thank you for not flaming, I know I sound like a noob.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I know Jack about electronics, so this diagram is worth what you paid for it. I'm not responsible if my ignorance burns up your display card and power supply. Maybe someone else can comment on what's wrong in the picture.
    Find out what kind of voltage is coming out of the regulator. Is it just one voltage or two? I think maybe just one because of what looks like transformers downline. If it is just one type of voltage, you can supply that voltage where it comes out of the rectifier.
    Of course, once you start unsoldering the rectifier and replacing it with your stuff, the process is pretty much irreversible. You'll either get it to work, or it will become a doorstop.
    You might want to check and see where the inverter is getting its power from. If it is from the AC input, you are also going to have to figure out how to supply or replace the inverter. And be CAREFUL around the inverter! It jumps power up to the thousands of volts range to run the CCFL tubes. Even getting close to the transformer over there can cause you to get a nasty shock.
    Want to:
    Jul 2008
    Detroit
    So if I understand correctly, the power is rectified to dc and then converted to two different voltages using the regulators? So I would want to find the voltage after the rectifier and feed it what it wants and let it regulate that current into whatever it needs? Also, if I do F up this board, I can replace it for $30.
  1. dc - ac power inverter
    By dasaint80 in forum Power Supplies
    Last Post: 12-10-2005, 03:16 PM
  2. Possible to turn a DC Toggle switch into AC???
    By Defiler in forum General Hardware Discussion
    Last Post: 07-05-2004, 08:29 PM
  3. AC or DC power supply w/ tablet pc?
    By gutterslide in forum Power Supplies
    Last Post: 04-07-2004, 03:12 AM
  4. dc or ac power supply
    By qball008 in forum Power Supplies
    Last Post: 05-16-2002, 10:22 PM
  5. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 12:27 PM
