i'll take this one guys...
composite video (no tuner-straight to monitor) uses rca's. if you have a cable that came with the board and it has an rca female jack on it you can use that too.
Ok you guys are probably going to think this is dump (and if you do my excuse is I'm a new member hehe). I'm looking at a motherboard (EPIA M 9000) which has tv out (composite and S-video). Im also looking an LCD Monitor from digitalww.com (7" in-dash) which has two video inputs (RCA). My question is, what exactly is tv out? I mean is it the RCA that this LCD needs? If this is not the RCA connections the LCD needs then what do I need to hook the motherboard (witht the built in video) to the Screen?
thanks, now that helps a lot. I only need to choose a dvd and powersupply now.![]()
Ok I have one more question...I've just recently heard that if the LCD monitor doesn't have vga thenit won't display text well. So if I have a tv out (composite) and connect it straight to my lcd monitor, then will it display text like a regular computer monitor or will it display as a tv set would?
Using a rca cable with tv-out it will display text like a tv, maybe slightly better, but not nearly as well as a computer monitor. You would most likely have to boost up the font size in windows if you want to be able to read it.
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
TV (whether PAL or NTSC) is a LOW-RESOLUTION SIGNAL as compared to computer resolutions, even plain old vanilla VGA. Also, for small screens, I strongly recommend using 640x480 (refresh rate does not matter, default reduces the requirements of the monitor and the PC).
