Results 1 to 6 of 6
Thread: Mulitple Lilliput Screens under Windows and Touch
    Aug 2008
    When I read the details on the touch software that came with the 7" Lilliput screens it mentions support for mulitple monitors.
    When I installed the two 7" Lilliput and touch drivers, the touch setup does imply that it should support distinct touch to each screen (it asks to touch a screen, then shows the ui on the other screen, than asks to touch again as though configuring the association of touch device and screen). But what ends up happening is that either both Touch interfaces effect the primary screen or at least once it showed touch going to the general right location BUT not consistent across the surface of each (messed up).
    Has anyone every got this setup correctly?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I didnt use the software that came with the lilliput because I lost the CD. I went to this site, http://touchkit.com/Drivers.htm#xp. I have 3 Lilliput EBY701s and this software works perfectly. My setup is alittle awkward, so it will say I have 2 screens, but then underneath will say 3 touch panels. I dont know if this is the same lilliput uses, but I like this one and it has only caused me problems one time, but a simple reinstall fixed it.
    PS: I use version 4.3.8.4207 which is the one all the way to the right side.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Aug 2008
    Unhappy
    That software shows no support for USB touch devices (of which mine are). After the install it placed no shortcuts either on the desktop or in any start menus, and nothing was running. I can remove it is all. I suspect that since it didn't enumerate any touch devices (due to them being USB) it didn't finish the install correctly.
    Jul 2007
    Miami
    HUH, thats weird, it did so on mine. Only thing I did have to do is put the shortcut in the startup folder. It does not do it on its own. Other then that the software put icons on my desktop and program list area. All 3 of mine are USB also.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Aug 2008
    Solved.
    The default software does work, it just wasn't intuitive. When the TouchKit application is showing the two screens and in little text states to double click to use this device association, you should do this...
    First, I have a mouse installed for setup, so I have to use it until the touch screens are associated.
    Second, move the App to the screen of choice, then double click the virtual screen area for that screen, then move the app to the other screen and then double click the virtual screen area for that screen. Then it just works. Moveing the application was not obvious.
    Jul 2007
    Miami
    Quote Originally Posted by Makuna View Post
    Solved.
    Thanx for the heads up........
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 05:20 PM
  3. Lilliput 7" (first model) touch function dead
    By holistic in forum LCD/Display
    Last Post: 09-28-2005, 02:27 AM
  4. Windows not detecting Lilliput USB TS
    By chapstick in forum LCD/Display
    Last Post: 05-02-2005, 04:49 PM
  5. Replies: 36
    Last Post: 12-31-2004, 04:37 PM
