Results 1 to 7 of 7
Thread: 700tsv issue, is this fixable???
    Aug 2008
    Been lurking for a while but now I have a question
    I was wondering if this was fixable or not it is a 700tsv couple years old never been opened.
    Any help will be good everything else works (touch,aux in,vga) except it has vertical lines.
    Oct 2006
    Strange issue, i have no idea myself, check if your ribbons are properly connected.
    Other than that its probaly your LCD or your controller that's broken.
    If you need a controller, i have a working one for sale.
    Aug 2008
    Well I guess no on knows, I wonder how much I could get for it if i sold it, anyone know a good asking price?
    Vendor - Qube colin's Avatar
    Dec 2006
    A ribbon cable is most likely the cause.
    Check the ones that leave the controller and go into the screen... push those around and youll notice that different patches go on/off.
    Mine's having the same problem and it's ****ing me off.
    Oct 2006
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    As mentioned the most likely cause is the ribbon cable going into the controller.
    If re-seating it doesn't help , then the second most likely reason is the ffc cables that go from the small circuit board on the back of the Lcd into the lcd. There are usually 3 of them along the bottom of the lcd.
    Push them down one at a time with your finger. If the line goes away then you found your problem. Then you will need to find a way to clamp it permanently or glue it down.
    Aug 2008
    Quote Originally Posted by Punky View Post
    Not really because now I have to buy a new screen according to that page
  1. No audio after resume from hibernate issue - almost fixed - Help me finish?
    By Trin in forum Software & Software Development
    Last Post: 07-26-2008, 07:35 AM
  2. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 05:29 AM
  3. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 10:00 PM
  4. 700TSV annoying issue
    By Cheekz185 in forum LCD/Display
    Last Post: 01-23-2008, 12:06 AM
  5. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
