Results 1 to 10 of 11
Thread: Powering my Screen off of M2-ATX?
    Dec 2007
    Thumbs up Powering my Screen off of M2-ATX?
    I have an extra plug on my ATX cable, can i use this to power my VM80 screen? The plug has a yellow, red, and black wire. Do i use the red or yellow for the positive?
    Elsewhere
    Does the screen accept 12vdc?
    It probably does, but I would verify before attempting anything, to prevent the risk of damaging equipment.
    The color of the wires isn't going to help at all.
    How about the Wiki?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    If the screen is designed to run from the cigarette lighter (+12V unregulated) you can connect it to the M2 provided that you have not maxed out the current usage already. Use a voltmeter to verify that the correct voltage and polarity is observed. The Yellow wire of the M2 molex should give +12 and both black wires are ground. You have to figure out the screen end yourself.
    ~Jimmy
    Dec 2007
    The screens safe power supply: DC 12V (10V-14V)
    Rated Voltage: DC 11.5-14.5(600ma)
    Will this work?
    Dec 2006
    ive got my lilliput running off of my M2-atx psu just fine.
    Nov 2005
    Austin, Texas
    Quote Originally Posted by Roadmaster11 View Post
    Will this work?
    yep
    ~Jimmy
    Jun 2008
    Quote Originally Posted by dj3stripes View Post
    yeah me too
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    in an ATX wire harness, the standard wire colors are BLACK=[GROUND], YELLOW=[+12V], and RED=[+5V].
    Will this work?
    while it certainly wouldn't hurt to power your screen from your M2-ATX, it doesn't appear that you need to if your screen can accept a 10v-14v input.
    FLAC WuNgUn's Avatar
    Sep 2007
    Me too...works perfectly
    Jun 2008
    Quote Originally Posted by FusionFanatic View Post
    My lilliput also did support those Voltage's but then connected to the battery it didn't survive it, so i had to get a new one.
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  3. M2 ATX with remote starter question?
    By david69leonard in forum Power Supplies
    Last Post: 02-05-2007, 06:50 AM
  4. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
  5. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
