Results 1 to 9 of 9
Thread: LinITX 7" TRANSFLECTIVE Dismantled??
    Dec 2007
    Iowa
    Has anyone taken apart the linitx transflective screen? I'm wondering if i can mount in my dash fairly easily. I assume someone has to have done it by now.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The Linitx's are very similar to the Lilliputs.
    The 7" actually uses the same Hitachi Panel as the lilliputs (I assume the transreflective does as well), so if you search for info on the lilliputs it should give the screen size.
    Dec 2007
    Iowa
    I'm not too worried about the screen size i'm more worried about this all in one cable. I'm not even sure if that is going to work. I don't see how that would fit into a vga slot. Maybe i'm missing something obvious.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    All in one is the part that is on the Monitor end.
    At the PC end you will have a VGS connector, 2 or 3 Video (phonos) connectors and if you have touch screen a USB connector.
    There is also I think one barewire which is desigend to go to a reverse light if you use one of the inputs as a reverse camera.
    Dec 2007
    Iowa
    So there is some sort of an adapter?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The monitor has a small lead coming out of it which terminates in a multiconnector. You are provided with a 2 or 3m lead which connects to the multiconnector and has the ends I specified above.
    Dec 2007
    Iowa
    ahh i c. They should show pics of that, Thanks a lot
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    This shows the connector
    And this shows you what the package consists of (It's not the transflective but they are basically the same)
    Dec 2007
    Iowa
    Cool thanks!!
  1. Replies: 8
    Last Post: 09-30-2008, 10:02 AM
  2. CarTFT Transflective vs LinItx Transflective
    By Triad.: in forum LCD/Display
    Last Post: 06-28-2008, 03:41 AM
  3. New LinITX transflective - any reviews?
    By wywywywy in forum LCD/Display
    Last Post: 06-16-2008, 03:10 PM
  4. LinITX 7" HB blank screen when windows loads
    By maddop in forum LCD/Display
    Last Post: 12-01-2007, 09:07 AM
  5. CarTFT's MM400 7" and LinITX 7" same thing?
    By loscooby in forum LCD/Display
    Last Post: 05-13-2005, 01:40 PM
