Results 1 to 9 of 9
Thread: [Reportage] Backlight xenarc 700tsv 2008
    Newbie Alex88's Avatar
    Sep 2008
    Post [Reportage] Backlight xenarc 700tsv 2008
    HI, is my first message! however I wanted to ask if anyone knows how to control the backlight of 700tsv .. I made a small change with a potentiometer, but are not very convinced of my work ..
    Oct 2006
    you can't.
    Sep 2008
    I have really made the change, regulated by a potentiometer .. soon put a fotosensore for automatic luminance
    Sep 2008
    Cool
    is possible by changing the card (only) of the screen .. add photos of the amendment ..
    Sep 2008
    Exclamation
    1st! the screen on a bezel bmw
    Sep 2008
    2nd, the party retail
    Sep 2008
    3rd, The red mark is the track power of the integration of power
    cut where the black mark
    Sep 2008
    4th, check that there is more driving .. from condesa jumpered resistance SMD
    Sep 2008
    5th, linked by a potentiometer 680ohm or less between the 2nd leg of the aid to the bridge ..
    resistance 0ohm = max brightness
    resistance 680ohm = off brightness
    WARNING! The runway is to cut power, is covered by the power of CCFL, and then generates HEAT!
    The ideal would be a transistor stabilized!
  1. Xenarc 700TSV Doesn't Fit
    By zzzBrett in forum LCD/Display
    Last Post: 01-30-2007, 02:13 AM
  2. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 10:55 PM
  3. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 02:39 AM
  4. no image (backlight?) on Xenarc 700TSV
    By greenman100 in forum LCD/Display
    Last Post: 04-23-2005, 02:34 PM
  5. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 06:38 AM
