Results 1 to 6 of 6
Thread: Lilliput 629 touch screen hibernation issue
    Jun 2006
    I recently replaced an old Dynamix monitor with a Lilliput 629GL-70NP. The problem I am running into is when resuming from hibernation the touch screen portion does not work at all. My other USB devices (GPS, Keyboard, WiFi etc.) work just fine when resuming from hibernation.
    I also though it was weird that I need to reboot Windows XP twice before it recognizes the touchscreen again. If I just reboot it once I still have the same problem where the touch screen does not work. I never had this issue with the Dynamix touch screen. Any idea what the problem could be?
    Thanks,
    SPECS:
    Windows XP SP3
    Intel Atom D945GCLF2 motherboard
    1GB RAM
    M2ATX Power Supply
    Lilliput 629GL-70NP monitor
    Elsewhere
    Is the touchscreen going through a USB hub by any chance?
    How about the Wiki?
    Jun 2006
    Quote Originally Posted by DarquePervert View Post
    No, it is plugged into one of the four on board USB ports. I also tried relocating it to another USB port with no luck.
    Also, I am using the driver on the CD included with my monitor because the download section on Lilliput's website is down.
    Elsewhere
    Look int eh FAQ Emporium. There's a thread in there with a link to the most current touchkit drivers.
    That may resolve your problem.
    How about the Wiki?
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Smile Check this...
    While touchscreen is running check system propeties goto your touchscreen make sure in the power section that the box that says allow computer to cut power(or something like that) to this device to conserve power isn't checked. I had a similar prob and this solved it. It's worth a shot if you hadn't already.
    Jun 2006
    Well one link in the FAQ is directed to Lilliput's website which is down. The other link goes to the manufacturer of touchkit I think. Anyways, when I used the touchkit driver it didn't work at all.
    Quote Originally Posted by insaneramman View Post
    I noticed this before when troubleshooting earlier. I went ahead and unchecked it as you suggested and so far so good! Granted the car has only gone into hibernation mode once but I will check it again on my lunch break and see if its working. Thanks for the tip!
  1. Lilliput TOUCH SCREEN StOpS !!!!!!!!
    By vicky_obee in forum LCD/Display
    Last Post: 01-07-2007, 07:37 PM
  2. Lilliput 8" touch screen backwards - FC4
    By DJBigShow in forum Linux
    Last Post: 08-04-2006, 03:43 PM
  3. FS: Lilliput 619gl-70np/c/t 7" touch screen
    By kingeorge36 in forum Classified Archive
    Last Post: 05-06-2006, 04:52 PM
  4. Lilliput Touch screen
    By Wendy in forum Newbie
    Last Post: 11-07-2005, 08:48 AM
  5. Lilliput 629 screen not clear - help
    By gdawg in forum LCD/Display
    Last Post: 09-28-2005, 09:34 AM
