Results 1 to 7 of 7
Thread: Touchkit is slow after standby
    Jun 2008
    Hi i have a 7" lilliput and a XP based computer in my car, but then i start up Xp from standby it might take up to 1 min before i can use the touchscreen, is there any solution for this?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by Dragonlove View Post
    Any resolution? I am noticing the same thing now, but I believe it is more USB related.
    Mar 2006
    Colorado, but Canadian!
    Always connect your touchscreen directly to the motherboard's root USB port. Do NOT connect it to a hub, or this will happen.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    PA
    Quote Originally Posted by 2k1Toaster View Post
    Well mine is direct to the motherboard, infact I do not have a hub, my MB has 10 onboard USB. I am using 6. I noticed the device manager "Refreshing" when it is open as well as nvidia control panel. This tells be there is a USB device conflicting, not working, or just screwed. I am going to eliminate them 1 by 1 and hopefully find the culprut.
    Mar 2006
    You can try one of the programs that disconnect devices before hibernate and reconnect on resume. Might work.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Hibernate trigger works with both standby and hibernate.
    Nov 2007
    PA
    I am already running Devcon for GPS... I unplugged my USB Wifi and the "refreshing" stopped..I am still having device issues though.. It seems like if one is working well the others work half a$$. I don't get it.
  1. Turning key from ACC to Crank = Laptop will standby
    By l00kster in forum Power Supplies
    Last Post: 11-15-2007, 02:27 PM
  2. DSATX and Standby
    By HyperZulu in forum Power Supplies
    Last Post: 06-14-2007, 05:33 PM
  3. Standby issue - goes into standby and comes right back out
    By ckny in forum General MP3Car Discussion
    Last Post: 03-25-2007, 08:10 PM
  4. Standby issues. Seriously confused here.
    By maxxell in forum General Hardware Discussion
    Last Post: 04-16-2005, 02:26 AM
  5. System Standby Failed (Touchkit)
    By Nokia6600 in forum Newbie
    Last Post: 03-18-2004, 08:24 AM
