Results 1 to 5 of 5
Thread: help with flickering lilliput 701 touchscreen in dash
    Aug 2008
    Talking help with flickering lilliput 701 touchscreen in dash
    hi,
    i have a car pc with lilliput 701 vga touchscreen in dash
    and i have a flickering problem (when the car is on or off its the same)
    - refresh rate is set to 72Hz.
    - the length of the vga cable is 5 meters.
    - (+) power cable is passing next to the vga cable from the battery (+fuse) to the power supply.
    what can cause this problem?
    what i need to check ?
    Sep 2007
    West Springfield, MA
    If the display is using a CCFL backlight, it could be that it's cold
    Edit: It could be that your power cable is near your VGA cable as well.
    Maximum Bitrate DeltaFX's Avatar
    France
    Try moving the power line away from VGA cable. There may be special concerns about how shielded is this vga cable
    Now Galileo is real. Muhahahahaha :p
    poz
    poz is offline
    Aug 2008
    i verified that the problem is not on vga
    using a 12v 1.4amp battery connected to the acc and the battery
    the screen looks good without any flickering so the problem must be
    unstable (+) ..
    im sure im not the first one with this problem
    what do you think i need to check \ do ?
    France
    If I understand, your puter is in the trunck so there's a 5 meter vga/usb/... cable. But how's your screen powered?
    Direct from the batt with a short cable (batt->fuse->(POL)->screen) ? or from your carputer's PSU (Batt -(5m)-> psu -(5 m)-> Screen ?
    Where is your scren grounded ? What are the +,- cables gauge ?
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Replies: 11
    Last Post: 10-10-2005, 10:05 PM
  3. F/S Lilliput 8" Touchscreen
    By kruben in forum Classified Archive
    Last Post: 07-19-2005, 02:24 PM
  4. Replies: 1
    Last Post: 01-31-2005, 12:35 PM
  5. Replies: 0
    Last Post: 01-25-2005, 12:55 AM
