Results 1 to 8 of 8
Thread: vga cable touch screen
    Oct 2008
    right guys iv got my screen
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...:B:WNA:GB:1123
    this is it. some cheap chinese thing. it had a few cables with it , one is like a s-video output to phono which fits in the back on the two slots av or vga. from there i put it into pc by a nvidia phono adapter and the picture quality was so bad i couldnt see anything.
    il try get a picture of the setup and if somebody could tell me what cable i need as i think im using the wrong one
    http://www.clanshout.co.uk/xox
    here is a folder of my pictures, the cables i use. if you can see why the picture quality so bad id appreciate it
    thanks
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the eBay link didn't work so I can only see your pictures. unless you left a picture out, it would appear that the monitor doesn't have a VGA input, one cable has a composite input, S-video input, and component inputs. the other cable has three RCA connectors (either an A/V input or an A/V output). is there a third cable with a VGA input?
    if it has no VGA input then the picture will look like crap no matter how you hook it up. of the available inputs, component would have the best picture but its unlikely that your video card would have a component video output. S-video is the next best, and composite is the worst. you can use them for a front end, but they are all incapable of displaying the small text that normal PC programs use.
    I also assume there is no touchscreen on that monitor? what will you be using as your input source (mouse, trackball, touchpad, etc)?
    Oct 2008
    on the picture DSC00902.JPG the vga text cant be seen as the flash sorry my bad. its the one on the left the one next to the dc input. its the same as the av connection, i tried an S-VIDEO cable and it wouldnt go in the hole
    also it is touchscreen and here is link http://cgi.ebay.co.uk/ws/eBayISAPI.d...:B:WNA:GB:1123
    also found this which may be useful http://item.b-billion.com/YAFA/YA808...TV_billion.htm
    Oct 2008
    http://cgi.ebay.co.uk/S-Video-8-Pin-...ayphotohosting
    think this is what i need? can u guys clarify
    Jun 2004
    Rochester
    That cable does not convert signals. It is for special PC video cards that have S-Video signals on some of the unused pins of the VGA connector. It does not work the other way, and will not work with your monitor. Your best bet is component input. Some graphics cards can output this via a breakout adapter, much like the one you showed a picture of (the one with the black boxy thing). Other than that, s-video or composite are your only options.
    Good Luck.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Fusion is correct, if you are connecting that device as a PC monitor, the picture will look like crap no matter how you hook it up because it's not a VGA unit.
    Stay away from those screens that have an S-Video output to a VGA adapter if you plan on reading standard sized text.
    Oct 2008
    there is vga port !!! its where the flash is, you cant see it! its 8 pin vga
    anways so if i used that cable id have to convert the signals still?
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by topman View Post
    if you open the case, you might able to identify the lines... there should be 5 to work: vertical and horizontal sync, green, red and blue signal. if you are lucky, you can identify them by tracking the lines on the PCB then compare it to the docs of the chips on the board. or i hope - nothing bad will happen ( gurus please confirm it ) if you try to connect this 5 pin randomly!
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  1. f/s: 7" Touch Screen VGA monitor
    By goomba in forum Classified Archive
    Last Post: 02-22-2007, 06:47 PM
  2. Replies: 6
    Last Post: 11-08-2006, 06:57 PM
  3. FS: 8" Xenarc VGA LCD Touch Screen
    By Fatigue in forum Classified Archive
    Last Post: 09-12-2005, 08:42 AM
  4. Replies: 6
    Last Post: 12-21-2004, 03:47 PM
