Results 1 to 8 of 8
Thread: How to power my screen?
    Aug 2008
    SouthernOK
    Yes I have read the sticky, but it didn't help. I have the 10.4" screen that is talked about in this thread.
    Powering from the cigarette lighter causes flickering on the screen.
    Is there a simple way to wire it to an m2?
    2004 F150 STX Heritage:
    Parts:
    ASUS E35M1-I Fusion AMD 1.6GHz DC ~$114
    Patriot 32GB SSD ~$80
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    10" Samsung touch panel - ~270
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by 04f150stx View Post
    Yup...very simple...
    Jump two of the ATX pins together (you'll have to look this one up yourself...it's covered elsewhere) to trick the M2 into thinking it's attached to a mainboard...
    Setup the jumper like you normally would...
    Then splice into any of the black (ground) and yellow (12V+) wires...
    If you want 5V for a USB hub as well, it's black and red.
    Of course, you have to hook it up to your ACC and power wires in the car as well...I power mine off the cig lighter after downgrading the fuse (15A)...I don't smoke
    Aug 2008
    SouthernOK
    My M2 is connected to a mainboard so tricking it isn't necessary.
    Those instructions sound like how to hook up the m2, not the screen. Am I understanding it right? My m2 is already connected and running.
    I'm wanting to hook the power for the monitor into the m2.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    Sep 2007
    Raleigh, NC
    If your PSU has enough available capacity, its as simple as connecting the 12v rails. This is the yellow(+) and black(-) on most PSU's, but use a multimeter to double check if you are unsure.
    Aug 2008
    SouthernOK
    Do I cut my cigarette lighter cord and use those wires?
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    May 2006
    Calgary, Alberta
    I'd rather cut up the AC plug as there's a better chance of me using my cigarette lighter adapter then there is of me using my AC adapter. But either way, just cut it and get access to the two wires in there. Then splice them into the correct wires of a molex connector (see above) that you can buy at any computer store for $1. Then plug into the molex connector from your M2, voila. I did it with my Xenarc.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    just FYI... you don't need to use both wires. only the +12v (yellow) wire is necessary. the M2's input and output grounds are the same, so you can wire the monitor's ground wire to any grounded chassis panel.
    Aug 2008
    SouthernOK
    Thanks everyone, it makes sense now.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 05:29 PM
  2. Replies: 116
    Last Post: 08-07-2008, 10:23 AM
  3. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 05:57 PM
  4. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 12:38 PM
  5. help with screen power
    By adidas445 in forum LCD/Display
    Last Post: 04-20-2005, 11:51 AM
