Results 1 to 5 of 5
Thread: only Lilliput can fit double-din?
    Nov 2007
    Hi,
    I've been researching for over a year and have finally started ordering parts. It seems that the LCD part is definitely the most confusing. After searching for LCD dimensions it seems to me that the Lilliput 629 or 701 can fit in a double-din (there're even double-din enclosures built for these screens) but Xenarc LCDs are just too big. Am I correct? I'd much rather install a Xenarc for the auto video switching feature since I'm going to install a backup camera but guess it's no luck. Anyway, just wanted to clarify before I make my purchase. Any suggestions/comments?
    Thanks in advance!
    May 2006
    Calgary, Alberta
    Xenarc fits double DIN just fine, here's a link to a thread with pictures of my Xenarc in my car.
    http://www.mp3car.com/vbulletin/lcd-...ouble-din.html
    No offense but it doesn't seem like you researched very hard.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Nov 2007
    Hi Maheriano,
    Thanks for your response. I did read that post you mentioned several times as well as tried to google for the dimensions of all the 7" LCD touchscreens. Although your posts does state that after trimming off most of the bezel it fit, I read the Xenarc sticky thread which shows that the LCD of the 700tsv is 171mm x 108mm which is taller than the double din opening my Metra kit allows. Furthermore, this post below by Archy88 shows that it's just too wide--hence my confusion.
    Quote Originally Posted by Archy88 View Post
    I have an 02 Mustang, with I believe 1.5 din opening. the 700TSV is JUST, JUST too wide. Maybe 1/8". Its also about 1" too tall. Some creative hacking will allow for a nice fit ;-)
    I'm trying to find a 7" LCD, screen only, that would fit the Metra kit for my car while utilizing a double din enclosure (see BLK02si's thread in Fabrication) without modification or trimming, if possible.
    Thanks again.
    May 2006
    Calgary, Alberta
    Without modification? That's going to be tough but there is a thread here with the exact measurements of every piece of the Xenarc.
    Why do you want to keep the bezel in one piece? Why not just buy an extra bezel and use it if you ever want to take the screen out?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Im finally going to make the jump and go from a single din flip out to a double din setup. I just bought an eby701 and a universal double din adapter:
    http://cgi.ebay.com/UNIVERSAL-RADIO-...3286.m20.l1116
    Ive looked through a few member's installs with this monitor, and it seems to fit the double din opening snugly. Before buying this monitor, I actually cut a piece of paper with the exact dimensions of the screen and compared it to my car's dash. It seems to fit perfectly in the double din opening, but of course I cant say for sure until everything comes in. My plan is to fab the monitor into the double din adapter and just slide that into the dash.
    Anyways, its just something you might want to consider...
  1. Looking or Double Din Touchsreen soultion
    By DjKoZoTo in forum LCD/Display
    Last Post: 10-16-2008, 06:41 PM
  2. Replies: 3
    Last Post: 02-27-2008, 07:49 AM
  3. 2004 Honda Accord Upper Double Din – IVA-W200
    By EricRhinehart in forum Car Audio
    Last Post: 02-10-2007, 01:21 AM
  4. DOUBLE DIN Dilemma
    By BLAXKINNED in forum LCD/Display
    Last Post: 02-04-2007, 03:03 PM
  5. FS: Lilliput 701 w/ DIN housing
    By dynamok in forum Classified Archive
    Last Post: 11-23-2006, 12:34 AM
