Results 1 to 10 of 15
Thread: Multi Monitors with multi vidcards
    Dec 2002
    Illinois
    I want to set up a system where I can play movies games etc in the back while still using gps etc in the front I was thinking maybe I could achieve this with another video card I curently have an ati and Ive messed around with the extended desktop thing but that doesnt work the way I want it to Im not going to do anything at the moment and prob not till taxes come back
    Jan 2003
    I like the matrox dual-headed cards. They have
    the best 2D output (in my opinion), and are cheap.
    I have two at home and never had any problems. One for dual display on a desktop, and one for the server in the closet: one monitor in the closet, and the other to the TV in the other room.
    Dec 2002
    Illinois
    Is it like havin two seperate desktops then
    Only prob i had was trying to get the video to play on both monitors
    Dec 2002
    Illinois
    Thanks for the help ill look at those
    Jan 2003
    Re: Is it like havin two seperate desktops then
    You could set it up various ways:
    Two separate independent screens (with separate keyboards / mice)
    One large desktop left->right or top->bottom
    Oh yea, this is under linux as I don't do windows.
    The cards do have built-in hardware scaling / colorspace conversion for mpeg / avi decode... I haven't tried it on two independent monitors at the same time. I'll try that tonight. ;-)
    Dec 2002
    Illinois
    linux hmm maybe
    never relly messed around with linux maybe someday Is it possible to use just one system ie mouse keyboard to control both monitors I think I prob wouldnt be able to run a game at the same time as a movie maybe Ill go all out and build two systems one for mp3s and one for video/gaming then run the monitors of them only concern would be power then ohh yeah and money
    Can you tell im still in the idea phase
    May 2002
    I think a video card for each screen is better i have a 3 screen setup right now. 3 19" monitors with a Geforce 4 ti (2 pci) and one (agp) It works pretty good.
    Constant Bitrate CA 3000GT's Avatar
    Jan 2003
    Palo Alto, CA
    Hmm, well, getting 2 displays is easy, getting 2 seperate terminals each of which taking seperate input, is not so easy.
    If you just want to view from one screen, and interact with the other screen, like:
    a) just see the gps, and use the game on the controller,
    or
    b) start the mp3s going, then switch focus to the game in back.
    Its no problem... just get a duel monitor setup with either a duel headed video card, or 2 video cards. Just think of the computer as seeing the two monitors as one big display. Just make sure you have enough processing power. Doing this should be easy and cheap.
    Input is the diffiicult part...
    Windows will only let you focus on one program at a time, so if you run a gps and a game, the respective users have to take turns entering in commands.
    1995 SL stock
    Working On: GMAT
    Given Up On: Custom motorized lcd
    Apr 2002
    North Yorkshire, UK
    I have seen in the past a device which plugs into a PCI slot of a PC and gives you kbd, mouse, vga, sound outputs to run another user from the same box. It is supported in Windows, tho it might be NT/2K only.
    This is going back a while tho, when a PC was still relatively expensive, about 4 years?
    I dont know where to sart looking for it, tho it did exist at one time, definately.
    Dave
    Jan 2003
    Palo Alto, CA
    Really? I wonder what that was? are we talking windows NT?, XP, or more advanced versions?
    I belive once Microsoft started putting out server OS editions they made some effort to limit the concurrent use of multiple sessions with thier products, that card probibly only works on server level OS products.. would be very useful tho, perhaps not for a car application, but for an in home application
    MS SQL personal edition for example only allows 1 connection at a time MS IIS server only allows like 1 at once I think...
    Whereas the server editions can have... many.
    98explorerxlt, I really think your best bet is:
    - 2 ITX systems, even if you did get two sessions w/ seperate mice, keyboard inputs... you would still have to worry about sound... and then there is processing power... I think 2 full windows with 2 full apps at once may well move you out of the ITX range. I mean, the overhead involved in 2 sessions + 2 process intensive programs, it would be a strain on a ITX M9000.
    I mean, why not have 2 small cheap, easy to install boards, instead of 1 larger, harder to install board that costs twice as much, and is a great pain to set up?
    - One opus power supply, branch the ATX plug, so you have 2 plugs to power 2 mobos.
    (The Ominous, I apologise, you mentioned the os in your post, but I missed it in my origional version of this post)
    1995 SL stock
    Working On: GMAT
