Results 1 to 6 of 6
Thread: Current state of the 800x480 issue?
    Feb 2004
    I have an old Xenarc 700TSV and a Via EPIA M10000 running at 800x600. I did some searches to see if anyone has had recent success with 800x480 and found some people are reportedly running at 800x480 using ATI & Nvidia graphics cards. Has anyone been able to successfully get 800x480 to work correctly on a Xenarc 700TSV with a newer Via embedded board (mini-itx or smaller)?
    Mar 2005
    Quote Originally Posted by Mears View Post
    You dont need a graphics card just an IGP. You can get a nvid mini-itx board quite cheaply. It will take less effort than trying to make something work from a company who will not support you.
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Not to hijack anything here but a quick question? WHY is everyone so obsessed with 800X480? I run 800X600 and it fits just fine, is big enough to read etc..What is the big advantage that everyone strives for this resolution???
    Newbie deanb2's Avatar
    Sep 2008
    Calgary, AB
    Umm the physical resolution of most of the touchscreens is 800x480. So, in theory, the displays should look a lot better if the video card outputs at that resolution.
    Dean
    Nov 2007
    In practice, the difference is very small. I've run mine at both resolutions but ended up going with a laptop that can't do 480. I's really a non-issue, IMO.
    Mar 2005
    It just depends on the user. I ran at 800x600 for awhile mainly b/c I wanted better resolution, but it was definitely far inferior to running native res for me. It will depend on other factors like what software and skin you use though.
  1. Issue with RR not updating current song info
    By MillerTyme in forum Road Runner
    Last Post: 06-09-2010, 01:16 AM
  2. Current state of Dual Monitors
    By N6BER in forum StreetDeck
    Last Post: 03-28-2007, 09:20 AM
  3. Has anyone EVER gotten a Lilliput to detect 800x480?
    By larry_llama in forum LCD/Display
    Last Post: 12-03-2006, 03:05 AM
  4. 800x480 60HZ vs 800x480 61HZ?
    By theheel in forum LCD/Display
    Last Post: 04-25-2005, 10:42 PM
  5. Lilli 7" XP monitor type Won't sync 800x480
    By BMVEE in forum LCD/Display
    Last Post: 03-24-2005, 09:46 AM
