Results 1 to 3 of 3
Thread: Clean power for my lilli>?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have lilliput 7" that I have been running off an M2-ATX supply for a year now. he power has seemed to work fine and has been clean without any screen distortion or lines. Recently after having GPS issues I disabled the "Turn USB hub off" in Device manager to solve the GPS problem. Now it would seem the M2-ATX is under more load/draw and the screen is starting to get lines and bounce occasionally. I originally had the screen running off the 12v switched for my vehicle but that was messy too. Any good solutions or separate devices I could use to give good regulated power to my screen? Should i upgrade the PSU? Thanks...
    Nov 2007
    PA
    Guess not
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    if 1A is enough, LM2941 low-drop voltage regulator is your friend!
    drive a dedicated power cable (with fuse!) from the battery for the supply, put a 1-2-5-10K uF condensator after it, and this will solve the noise and power problems! you can turn on and off the supply with an optocoupler, driving it with any 5-12V line of the carpc supply
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Finalizing Power Supply Options
    By Nstyle in forum Power Supplies
    Last Post: 04-01-2007, 04:40 PM
  3. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
