Results 1 to 5 of 5
Thread: Can composite input be selected by hw?
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    I have a CID 650 that has an input to select AV2 input. Set the input to 12V and the rearview camera is enabled.
    I have tried to find out if it's the same with lilliput and xenarc panels without success.
    Thing is I've designed a box to control the LCD panel inputs among other things and I would like to know if my box can be used with those panels, or if I can modify it to do that.
    Sep 2005
    It seems like both Lilliput and Xenarc will switch in rearview camera when signal is present.
    But the Lilliput require some sort of configuration first to achieve this.
    Am I correct, or have you got more info? Maybe you know how to configure the Lilliput? (I have not been able to find that out)
    Mar 2006
    Colorado, but Canadian!
    Xenarc has the ability out of the box.
    Lilliput requires a soft-hack to the firmware through button combination on the remote.
    But yes both will work
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2009
    does anyone know where i can find info on how to soft hack the lilliput? i have had NO luck finding any info.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It's a sticky in the display forum called "Everything you need to know about your Lilliput"
    Want to:
  1. Replies: 5
    Last Post: 01-14-2008, 02:37 AM
  2. GM Radio Bus / Aux input
    By TucsonZ71 in forum Hardware Development
    Last Post: 08-21-2007, 12:29 AM
  3. Kenwood Composite Input
    By alphadan in forum General Hardware Discussion
    Last Post: 10-24-2005, 03:53 PM
  4. HELP, Input Signal to AMP
    By Power_nisse in forum Car Audio
    Last Post: 06-22-2005, 12:35 PM
  5. Replies: 4
    Last Post: 03-13-2004, 10:42 PM
