Results 1 to 4 of 4
Thread: LCD screen 12 v power ?????
    Jan 2009
    hey just brought a TFT lcd monitor for my car, at the end there is a black and red wire to power it ??
    where can i plug these in???
    Jan 2007
    Szeged, Hungary
    Is there any documentation about your unit?
    If the doc says, the input voltage is between 6-14V then you can connect it directly to the car electric system (black - ground/metal chassis and red to the +12V/positive pole).
    For a try, you can use the cigarette lighter socket (central electrode at the bottom: +12V, metal rim around: grond)
    If the unit needs exactly 12V, you have to buy a stabiliser (small, cheap electric unit) circuit. In that case connect cig lighter to the stabiliser and the stabiliser to the monitor.
    Alopecia perniciosa
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by bbalazs View Post
    SNIP
    Or power it from the PC power supply (if you have the overhead for the monitor to use)
    TruckinMP3
    Read the FAQ!
    Jan 2009
    sam515
    Hey is draws 8 watts of power.
    i brought one of these http://cgi.ebay.com.au/Fused-Cigaret...3A1|240%3A1318
    will it work ??
  1. Lcd Screen 12v power???? Help
    By sam515 in forum LCD/Display
    Last Post: 01-20-2009, 04:09 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  4. Splicing Power from Head unit for lcd screen??
    By pinga in forum Power Supplies
    Last Post: 07-18-2006, 10:35 PM
  5. Power Acoustik 5.6" Lcd screen HELP!!!
    By trilogy98 in forum General Hardware Discussion
    Last Post: 09-05-2000, 11:29 AM
