Results 1 to 10 of 11
Thread: Just bought a transflective monitor off ebay
    Nov 2008
    Hope it works good
    For $458.59 US Delivered (works out close to $700 AU).
    I just hope it works as good as the other transflective screens!
    Its a lilliput EBY701
    Here is the link if anyone is interested
    http://cgi.ebay.com.au/ws/eBayISAPI....m=220338268486
    I will write up when i get it in a week or so to tell you how it performs in the sun
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by shadoxity View Post
    Hope it works good
    If it hasnt shipped yet, I would contact the seller before it does. I dont see anywhere about optically bonding the touchscreen to the lcd panel itself.
    Those 3M films are off the shelf films that can be had for $20 USD. I applied them to my EBY701 myself as did many others. There is an improvement over the regular stock monitor, but it is not a real transflective. A real transflective bonds the 2 surfaces together (touchscreen glass panel and lcd glass panel) perfectly. No air/gaps between surfaces, no glare can form in that layer. There is more done to real transflectives too but that is the big one. These 3M films are just put behind the lcd glass panel (but still inside the overall lcd frame, not screen casing, but lcd frame) right before the mirrored finish basically. They arent bonded, they are loose and polarize light, but still have gaps. It will glare but only in more direct sunlight.
    So for that kind of money, I would expect more results. I would not get your hopes up on the screen, it is not a true transflective like you see in the mp3car store.
    Motorcity sells better transflectives, but again are still not the same quality as the mp3car ones. You do get what you pay for... Good Luck
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I believe the standard lilliputs may already have the 3M DBEF and BEF films installed. I took my EBY701 apart thinking I would install some spare 3M films, but the films already inside looked exactly like the 3M stuff.
    I would ask the seller to confirm what he means by "transreflective BEFII and ESR." Adding the 3M Vikuiti films does not make the monitor a true transreflective....you need to optically bond the touchscreen and LCD. I've installed ESR in my EBY701 and it does help with the brightness and sunlight visibility, but I would not consider it a true transreflective. It's visible 95% of the time...but when there is direct, bright sun hitting the screen at a certain angle, then you still cannot see anything.
    If the seller is selling the EBY701 with just ESR added and no optical bonding, then IMO, I think that is a ripoff.
    Mar 2006
    they do come with films that have the same purpose as the 3M films we (and this seller) are using, the oem ones arent polarized the same way and are not of the same quality. just as an fyi.
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    If you bought it off Motorcity I would advice getting a refund asap.
    Nov 2008
    Thanks for the feedback guys.
    Guess i will find out when i get it :P will let you all know then, fingers crossed
    Nov 2008
    soooo... what happen..???
    update please
    Nov 2008
    sorry forgot to update this,
    It was pretty crap, was better than a normal lcd, but not good enough so i sent it back and got a refund.
    Saving to get a real transflective. Probably going with the cartft one
    Mar 2006
    I again would recommend the mp3car one. It is the only one made that is optically bonded. They go through a lot of trouble to do it, and the results show.
    You are just trading 1 sub-par monitor for another little-better-than-sub-par monitor.
    I think my suggestion would weigh a little heavier since I was correct about the last screen...
    Nov 2008
    Quote Originally Posted by 2k1Toaster View Post
    Interesting, i did not know this.
    thanks for the info.
    doesnt look like they have any at the moment though :S
  1. NEC 8.4" Transflective Solution - Custom Kit
    By thermoptic in forum LCD/Display
    Last Post: 12-11-2010, 12:02 AM
  2. Replies: 20
    Last Post: 04-29-2009, 12:19 PM
  3. 2003 Nissan Xterra
    By tigergibb in forum Worklogs
    Last Post: 07-04-2008, 08:34 PM
  4. Transflective lilliput for 549! 18 left :)
    By mbkowns in forum LCD/Display
    Last Post: 02-26-2008, 01:46 PM
  5. just bought this on ebay
    By zupanm in forum LCD/Display
    Last Post: 02-07-2002, 12:28 PM
